Datasheet IRFP450N (Vishay) - 2
ManufacturerVishay
DescriptionPower MOSFET in TO-247 package
Pages / Page8 / 2 — IRFP450N, SiHFP450N. THERMAL RESISTANCE RATINGS. PARAMETER SYMBOL. TYP. …
File Format / SizePDF / 187 Kb
IRFP450N, SiHFP450N. THERMAL RESISTANCE RATINGS. PARAMETER SYMBOL. TYP. MAX. UNIT. SPECIFICATIONS. TEST. CONDITIONS. MIN. Static. Dynamic
IRFP450N, SiHFP450N THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP MAX UNIT SPECIFICATIONS TEST CONDITIONS MIN Static Dynamic
IRFP450N, SiHFP450N
Vishay Siliconix
THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. UNIT
Maximum Junction-to-Ambient RthJA - 40 Case-to-Sink, Flat, Greased Surface RthCS 0.24 - °C/W Maximum Junction-to-Case (Drain) RthJC - 0.64
SPECIFICATIONS
TJ = 25 °C, unless otherwise noted
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-Source Breakdown Voltage VDS VGS = 0 V, ID = 250 µA 500 - - V VDS Temperature Coefficient ΔVDS/TJ Reference to 25 °C, ID = 1 mA - 0.59 - V/°C Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250 µA 3.0 - 5.0 V Gate-Source Leakage IGSS VGS = ± 30 V - - ± 100 nA VDS = 500 V, VGS = 0 V - - 25 Zero Gate Voltage Drain Current IDSS µA VDS = 400 V, VGS = 0 V, TJ = 125 °C - - 250 Drain-Source On-State Resistance RDS(on) VGS = 10 V ID = 8.4 Ab - - 0.37 Ω Forward Transconductance gfs VDS = 50 V, ID = 8.4 A 7.9 - - S
Dynamic
Input Capacitance Ciss - 2260 - VGS = 0 V, Output Capacitance Coss VDS = 25 V, - 210 - f = 1.0 MHz, see fig. 5 Reverse Transfer Capacitance Crss - 14 - pF VDS = 1.0 V, f = 1.0 MHz - 2410 - Output Capacitance Coss VGS = 0 V VDS = 400 V, f = 1.0 MHz - 59 - Effective Output Capacitance Coss eff. VDS = 0 V to 400 Vc - 110 - Total Gate Charge Qg - - 77 I Gate-Source Charge Qgs V D = 14 A, VDS = 400 V, GS = 10 V - - 26 nC see fig. 6 and 13b Gate-Drain Charge Qgd - - 34 Turn-On Delay Time td(on) - 20 - Rise Time tr VDD = 250 V, ID = 14 A - 63 - R ns G = 6.2 Ω,VGS = 10 V, Turn-Off Delay Time td(off) - 29 - see fig. 10b Fall Time tf - 25 -
Drain-Source Body Diode Characteristics
MOSFET symbol Continuous Source-Drain Diode Current I D S - - 14 showing the A integral reverse G Pulsed Diode Forward Currenta ISM - - 56 p - n junction diode S Body Diode Voltage VSD TJ = 25 °C, IS = 14 A, VGS = 0 Vb - - 1.4 V Body Diode Reverse Recovery Time trr - 430 650 ns TJ = 25 °C, IF = 14 A, dI/dt = 100 A/µsb Body Diode Reverse Recovery Charge Qrr - 3.7 5.6 µC Forward Turn-On Time ton Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width ≤ 400 µs; duty cycle ≤ 2 %. c. Coss eff. is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 to 80 % VDS. www.vishay.com Document Number: 91232 2 S-Pending-Rev. b, 26-Jun-08 Document Outline Datasheet Disclaimer
