Datasheet PAM8408 (Diodes) - 9
| Manufacturer | Diodes |
| Description | 3W Stereo Differential Input Class D with Memory Up/Down Volume Control in SO-16L package |
| Pages / Page | 13 / 9 — PAM8408. Application Information. Input Capacitor (Ci). Undervoltage … |
| File Format / Size | PDF / 697 Kb |
PAM8408. Application Information. Input Capacitor (Ci). Undervoltage Lockout (UVLO). Short-Circuit Protection (SCP). E L
PAM8408 Application Information
(continued)
Large input capacitors are both expensive and space hungry for portable designs. Clearly, a certain sized capacitor is needed to couple in low frequencies without severe attenuation. But in many cases the speakers used in portable systems, whether internal or external, have little ability to reproduce signals below 100Hz to 150Hz. Thus, using a large input capacitor may not increase actual system performance. In this case, input
D
capacitor (Ci) and input resistance (Ri) of the amplifier form a high-pass filter with the corner frequency determined equation below,
E U
1
N
C f =
I
2π i R i C
T N
In addition to system cost and size, click and pop performance is affected by the size of the input coupling capacitor, Ci. A larger input coupling
O
capacitor requires more charge to reach its quiescent DC voltage (nominally 1/2 VDD). This charge comes from the internal circuit via the feedback
C
and is apt to create pops upon device enable. Thus, by minimizing the capacitor size based on necessary low frequency response, turn-on pops
SI
can be minimized.
D T Undervoltage Lockout (UVLO) R
The PAM8408 incorporates circuitry designed to detect when the supply voltage is low. When the supply voltage drops to 2.4V or below, the
A
PAM8408 outputs are disabled, and the device comes out of this state and starts to normal functional when the supply voltage increases.
P – Short-Circuit Protection (SCP) E
The PAM8408 has short-circuit protection circuitry on the outputs that prevents damage to the device during output-to-output and output-to-GND
T
short. When a short circuit is detected on the outputs, the outputs are disabled immediately. If the short was removed, the device is activated again.
E L O Overtemperature Protection S
Thermal protection on the PAM8408 prevents damage to the device when the internal die temperature exceeds +150°C. There is a 15-degree
B
tolerance on this trip point from device to device. Once the die temperature exceeds the thermal set point, the device outputs are disabled. This is
O
not a latched fault. The thermal fault is cleared once the temperature of the die is reduced by 60°C. This large hysteresis will prevent motor boating sound well and the device begins normal operation at this point with no external system interaction.
How to Reduce EMI (Electro Magnetic Interference)
A simple solution is to put an additional capacitor 1000µF at power supply terminal for power line coupling if the traces from amplifier to speakers are short (< 20cm). Most applications require a ferrite bead filter which shows at Figure 2. The ferrite filter reduces EMI around 1MHz and higher. When selecting a ferrite bead, choose one with high impedance at high frequencies, but low impedance at low frequencies. Ferrite Bead OUT+ 220pF Ferrite Bead OUT- 220pF
Figure 2. Ferrite Bead Filter to Reduce EMI
PAM8408 9 of 13 September 2025 Document number: DS36992 Rev. 2 - 4
www.diodes.com
