Datasheet RA (Fujitsu)
ManufacturerFujitsu
DescriptionMiniature Relay 2 Poles-1 to 2 A for Signal Switching
Pages / Page6 / 1 — MINIATURE RELAY. 2 POLES—1 to 2 A (FOR SIGNAL SWITCHING). RA SERIES. …
File Format / SizePDF / 187 Kb
MINIATURE RELAY. 2 POLES—1 to 2 A (FOR SIGNAL SWITCHING). RA SERIES. FEATURES. ORDERING INFORMATION
Datasheet RA Fujitsu
MINIATURE RELAY 2 POLES—1 to 2 A (FOR SIGNAL SWITCHING) RA SERIES
FEATURES
● Ultra high sensitivity ● High reliability-bifurcated contacts ● Conforms to FCC rules and regulations Part 68 —Dielectric strength 1,500 VAC between coil and contacts —Surge strength 1,500 V ● UL, CSA recognized ● Wide operating range ● DIL pitch terminals ● Plastic sealed type ● Latching type available ● Dial-pulse relay available ■
RA L – D 12 W – K [Example] (a) (b) (*) (c) (d) (e) (f ) (a) Series Name RA : RA Series Nil : Standard type (b) Operation Function L : Latching type Nil : Single winding type (c) Number of Coil D : Double winding type (d) Nominal Voltage Refer to the COIL DATA CHART (e) Contact W : Bifurcated type ( f ) Enclosure K : Plastic sealed type Note: Actual marking omits the hyphen (-) of (*) For movable and stationary contact with gold overlay type, add suffix ““-OH””. ■
SAFETY STANDARD AND FILE NUMBERS
UL478, 508 (File No. E45026) C22.2 No. 14 (File No. LR35579) Please request when the approval markings are required on the cover.
Nominal voltage Contact rating
0.5 A 120 VAC 1.5 to 48 VDC 2 A 30 VDC resistive 0.5 A 60 VDC 1
