Datasheet SBRFP2M60SAFQ (Diodes)
ManufacturerDiodes
Description2A Field Plated SBR Field Plated Super Barrier Rectifier in SMAF package
Pages / Page5 / 1 — SBRFP2M60SAFQ. Green. 2A FIELD PLATED SBR. FIELD PLATED SUPER BARRIER …
File Format / SizePDF / 293 Kb
SBRFP2M60SAFQ. Green. 2A FIELD PLATED SBR. FIELD PLATED SUPER BARRIER RECTIFIER. SMAF. Product Summary. Features. VRRM (V). IO (A)
Datasheet SBRFP2M60SAFQ Diodes
SBRFP2M60SAFQ Green 2A FIELD PLATED SBR FIELD PLATED SUPER BARRIER RECTIFIER SMAF Product Summary
(@ TJ = +25°C)
Features VRRM (V) IO (A) VF (MAX) (V) IR (MAX) (μA)
• Patented SBR Technology Provides an Avalanche Capability Five 60 2 0.58 12 Times Larger than Schottky Diodes Ensuring More Rugged and Reliable End Applications • Lower Reverse Leakage Ensuring Greater Stability at Higher Temperatures • Low-Forward Voltage (VF) Minimizes Conduction Losses and Improving Efficiency •
Description Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
This field plated Super Barrier Rectifier (SBR®FP) diode is ideally •
The SBRFP2M60SAFQ is suitable for automotive applications
suited for application requiring ultra-low blocking mode. Leading to
requiring specific change control; this part is AEC-Q101
lower operating temperatures and increased system reliability.
qualified, PPAP capable, and manufactured in IATF 16949
Packaged in the robust industry-standard SMAF package.
certified facilities. https://www.diodes.com/quality/product-definitions/ Applications Mechanical Data
• DC-DC converters • Package: SMAF • AC-DC rectifiers • Package Material: Molded Plastic, “Green” Molding Compound. • Reverse polarity protections UL Flammability Classification Rating 94V-0 • SMPS • Moisture Sensitivity: Level 1 per J-STD-020 • Freewheeling applications • Terminals: Finish - Matte Tin Annealed over Copper Leadframe. • Low-power consumption applications Solderable per MIL-STD-202, Method 208 • Polarity: Cathode Band • Weight: 0.035 grams (Approximate) SMAF Top View
Ordering Information
(Note 4)
Packing Orderable Part Number Package Qty. Carrier
SBRFP2M60SAFQ-13 SMAF 10000 Tape & Reel Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
FQ6 = Product Type Marking Code = Manufacturers’ Code Marking YWW = Date Code Marking Y = Last Digit of Year (ex: 5 for 2025) WW = Week Code (01 to 53) AB = Foundry and Assembly Code SBR is a registered trademark of Diodes Incorporated. SBRFP2M60SAFQ 1 of 5 September 2025 Document number: DS46513 Rev. 4 - 2
www.diodes.com
