Datasheet SBRFP3M60SAFQ (Diodes)
| Manufacturer | Diodes |
| Description | 3A Field Plated SBR Field Plated Super Barrier Rectifier in SMAF package |
| Pages / Page | 5 / 1 — SBRFP3M60SAFQ. Green. 3A FIELD PLATED SBR. FIELD PLATED SUPER BARRIER … |
| File Format / Size | PDF / 355 Kb |
SBRFP3M60SAFQ. Green. 3A FIELD PLATED SBR. FIELD PLATED SUPER BARRIER RECTIFIER. Product Summary. Features. VRRM (V). IO (A)
SBRFP3M60SAFQ Green 3A FIELD PLATED SBR FIELD PLATED SUPER BARRIER RECTIFIER Product Summary
(@ TA = +25°C)
Features
• Patented SBR Technology Provides an Avalanche Capability Five
VRRM (V) IO (A) VF Max (V) IR Max (µA)
Times Larger Than Schottky Diodes Ensuring More Rugged and 60 3 0.62 7 Reliable End Applications • Lower Reverse Leakage Ensuring Greater Stability at Higher Temperatures • Low-Forward Voltage (VF) Minimizing Conduction Losses and Improving Efficiency
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
This field plated Super Barrier Rectifier (SBR® FP) diode is ideally •
The SBRFP3M60SAFQ is suitable for automotive applications
suited for application requiring ultra-low blocking mode. Leading to
requiring specific change control; this part is AEC-Q101
lower operating temperatures and increased system reliability.
qualified, PPAP capable, and manufactured in IATF 16949
Packaged in the robust industry-standard SMAF package.
certified facilities. https://www.diodes.com/quality/product-definitions/ Applications Mechanical Data
• DC-DC converters • Package: SMAF • AC-DC rectifiers • Package Material: Molded Plastic, “Green” Molding Compound. • Reverse-polarity protections UL Flammability Classification Rating 94V-0 • SMPS • Moisture Sensitivity: Level 1 per J-STD-020 • Freewheeling applications • Terminals: Finish – Matte Tin Annealed over Copper Leadframe. •
e3
Low power consumption applications Solderable per MIL-STD-202, Method 208 • Polarity: Cathode Band • Weight: 0.035 grams (Approximate) SMAF Top View
Ordering Information
(Note 4)
Packing Orderable Part Number Package Qty. Carrier
SBRFP3M60SAFQ-13 SMAF 10000 Tape & Reel Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
FV6 = Product Type Marking Code = Manufacturer’s Code Marking
YWW
YWW = Date Code Marking Y = Last Digit of Year (ex: 5 for 2025)
FV6
WW = Week Code (01 to 53)
AB
AB = Foundry and Assembly Code SBR is a registered trademark of Diodes Incorporated. SBRFP3M60SAFQ 1 of 5 October 2025 Document number: DS46706 Rev. 4 - 2
www.diodes.com
