Datasheet SBRFP8A60P5Q (Diodes) - 2
ManufacturerDiodes
Description8A Field Plated SBR Field Plated Super Barrier Rectifier in PowerDI-5 package
Pages / Page5 / 2 — SBRFP8A60P5Q. Maximum Ratings. Characteristic. Symbol. Value. Unit. …
File Format / SizePDF / 402 Kb
SBRFP8A60P5Q. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics (Per Leg)
SBRFP8A60P5Q Maximum Ratings Characteristic Symbol Value Unit Thermal Characteristics (Per Leg)
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 60 V DC Blocking Voltage VRM Average Rectified Output Current IO 8 A Non-Repetitive Peak Forward Surge Current 8.3ms Single Half Sine Wave Superimposed on Rated Load IFSM 150 A Non-Repetitive Avalanche Energy (TJ = +25°C, IAS = 38.9A, L = 0.1mH) EAS 108 mJ
Thermal Characteristics (Per Leg) Characteristic Symbol Value Unit
Typical Thermal Resistance Junction to Ambient (Note 5) RθJA 11.2 °C/W Typical Thermal Resistance Junction to Case (Note 5) RθJC 1.6 °C/W Operating and Storage Temperature Range (Note 6) TJ, TSTG -55 to +175 °C
Electrical Characteristics (Per Leg)
Characteristic Symbol Min Typ Max Unit Test Condition
— 0.39 — IF = 4A, TJ = +25°C — 0.45 0.55 I Forward Voltage Drop V F = 8A, TJ = +25°C F V — 0.32 — IF = 4A, TJ = +125°C — 0.40 — IF = 8A, TJ = +125°C — 20 135 µA V Leakage Current (Note 7) I R = 60V, TJ = +25°C R — 6.7 — mA VR = 60V, TJ = +125°C Total Capacitance CT — 234 — pF VR = 60V, TJ = +25°C I Reverse-Recovery Time F = 0.5A, IR = 1.0A tRR — 47.5 — ns IRR = 0.25A, TA = +25°C Notes: 5. 2inch x 2inch Al board + 50mm x 50mm x 23mm Al heatsink. 6. The heat generated must be less than the thermal conductivity from junction to case: dPD/dTJ < 1/RθJC or junction to ambient: dPD/dTJ < 1/RθJA. 7. Short duration pulse test used to minimize self-heating effect. SBRFP8A60P5Q 2 of 5 September 2025 Document number: DS46703 Rev. 3 - 2
www.diodes.com
