Datasheet JX3S0040170M (JX Semiconductor)
ManufacturerJX Semiconductor
Description1700V, 40A, 72mΩ, N-Channel, Silicon Carbide MOSFET in TO-247-3L package
Pages / Page10 / 1 — JX3S0040170M. General Description. Features. Ordering Informations. …
File Format / SizePDF / 635 Kb
JX3S0040170M. General Description. Features. Ordering Informations. Applications. Order Number. Marking. Package Type. Packing Method
Datasheet JX3S0040170M JX Semiconductor
JX3S0040170M
1700V, 40A, 72mΩ, N-Channel, Silicon Carbide MOSFET Product Data Sheet JX-3T04-40A A/2
General Description
TheJX-MT3 series SiC MOSFET in TO-247-3L package ensures stable high-temperature operation for power-dense and energy-critical systems, enabling compact designs with reduced EMI.
Features
3rd Generation SiC MOSFET Technology High-Speed Switching with Low Capacitances High Blocking Voltage with Low RDS(on) Easy to Paral el and Simple to Drive RoHS Compliant, Halogen Free
Ordering Informations Applications Order Number
ASC40N1700MT3 EV Motor Drive
Marking
ASC40N1700MT3 High Voltage DC/DC Converters
Package Type
TO-247-3L Switch Mode Power Supplies
Packing Method
Tube Solar Inverters EV Charging
Key Parameters Symbol Parameter Values Unit Test Conditions Absolute maximum rating
VDS Drain-Source Voltage 1700 V TC=25°C ID Drain Current (Continuous) 40 A TC=25°C PD Power Dissipation 242 W TC=25OC TJ Junction Temperature 175 OC
Symbol Parameter Min. Typ. Max. Unit Test Conditions Static characteristics
- 72 88 VGS=18V; ID=20A; TJ=25°C RDS(on) Static Drain-Source on Resistance mΩ - 130 - VGS=18V; ID=20A; TJ=175°C
Dynamic characteristics
QG Total Gate Charge - 100 - nC VDS=1000V; VGS=-5/+18V; ID=25A; QGD Gate-Drain Charge TJ=25°C - 22 -
Source-drain diode
Q VGS=-5V; IF=20A; VR=1000V; rr Reverse Recovery Charge - 360 - nC di/dt=1000A/μs; TJ=175°C
Product Data Sheet
1
JX-3T04-40AA/2
Document Outline Thermal Characteristics Typical Performance Figure 1 Figure 3 Normalized On-Resistance vs. Temperature Figure 2 Figure 4 Typical Performance Figure 5 Figure 6 Body Diode Characteristic at 25°C Figure 7 Figure 8 Typical Performance Figure 9 Figure 10 Figure 11 Figure 12 Typical Performance Figure 13 Figure 14 Figure 15 Figure 16 Typical Performance Figure 17 Figure 18 Contact Info
