Datasheet SLG46801 (Renesas)
ManufacturerRenesas
DescriptionGreenPAK Programmable Mixed-Signal IC, VDD Range: 1.71-5.5V, 10 GPIOs, 2 ACMPs, Multi-Time Programmable, I2C in STQFN-12 package
Pages / Page7 / 1 — 110 – Objective. Description. CFR0011-110-00 Rev. Rev. 0.45. Specificat. …
File Format / SizePDF / 201 Kb
110 – Objective. Description. CFR0011-110-00 Rev. Rev. 0.45. Specificat. A io. prn. 23, 2026. Erebus/D33900 Confidential. Applications
Datasheet SLG46801 Renesas
Specifications in this document are tentative and subject to change Advance Datasheet SLG46801V-PR Multi-Time Programmable GreenPAK IC in STQFN Packaging ■ I2C Compatible Serial Interface
110 – Objective Description
CFR0011-110-00 Rev Rev. 0.45
Read Back Protection (Read Lock)
Specificat A io prn. 23, 2026 7
The SLG46801V-PR integrates the most popular ■ Three Combination Function Macrocel s
mixed-signal functions with multi-time programmable ● © 2026 Renesas Unauthorized disclosure is 3-bit LUTs or DFF/LATCHs with Reset/Set
In
Pa
te
g
r
e
n a
1
l
o f 7 memory to provide a low power, highly flexible Electronics strictly prohibited ■ Three Multi-function Macrocel s component for commonly used analog signal processing and mixed-signal functions. Individual ● Selectable DFF/LATCHs or 3-bit LUTs + 8-bit analog comparators used in conjunction with Delay/Counters configurable logic provide a way to solve a wide ■ Programmable Delay with Edge Detector Output variety of tasks with minimal costs. ■ Three 8-bit Delay/Counters The non-volatile memory (NVM) used in the device is ■ Two Oscil ators (OSC) programmed via the configuration software and once ● 10 kHz Oscil ator deployed in the end application, can be ● 25 MHz Oscil ator reprogrammed for bug-fixing or device upgrades. ■ Power-on Reset (POR) with Optional CRC The SLG46801V-PR offers an I2C serial ■ 1.71 V to 5.5 V – operating and program/erase communications bus for interfacing with the system VDD Range and it is also used for MTP re-programming. With a ■ 12L 1.6 mm x 1.6 mm x 0.55 mm, 0.4 mm pitch very low voltage operating voltage range of 1.71 V to STQFN package 5.5 V, the device offers extremely high flexibility for a ■ -40 °C to +105 °C Operating Temperature Range wide variety of applications while occupying a minimum amount of board area. The device is
Applications
available in the STQFN 12 lead package with a 1.6 ■ Consumer electronics mm x 1.6 mm x 0.55 mm size, offering smal size and high GPIO count for industrial applications. ■ Handheld and portable electronics ■ Industrial automation and process control
Features
■ Personal computers and servers ■ Multi-time programmable (MTP) memory for in- ■ Battery voltage and current monitoring system programming ■ Smartphones and fitness bands ■ Two high-speed analog comparators (ACMP) ■ Notebook and tablet PC ■ Two tolerant GPIO pins - can be safely driven Specifications in this document are tentative and subject to change above VDD Advanced/Preliminary Datasheet
SLG46801V Advanced/Preliminary Datasheet
SLG46801V R19DS0182EU0045 Rev. Page Multi-Time Programmable GreenPAK IC in WLCSP and STQFN Packaging 0.45 1 Apr. 23, 2026 R19DS0182EU0045 Rev. 0.45 Page 1 Apr. 23, 2026 © 2026 Renesas Electronics R19DS0181EU0045 Rev.0.45 Page 1 Apr. 23, 2026 © 2026 Renesas Electronics
