Datasheet SLG46801 (Renesas) - 3
ManufacturerRenesas
DescriptionGreenPAK Programmable Mixed-Signal IC, VDD Range: 1.71-5.5V, 10 GPIOs, 2 ACMPs, Multi-Time Programmable, I2C in STQFN-12 package
Pages / Page7 / 3 — SLG46801V Advance Datasheet. Pin Number. Pin Name. Description. Table 2. …
File Format / SizePDF / 201 Kb
SLG46801V Advance Datasheet. Pin Number. Pin Name. Description. Table 2. Functional Pin Description. Signal. Function. Input Option
SLG46801V Advance Datasheet Pin Number Pin Name Description Table 2 Functional Pin Description Signal Function Input Option
12 GPIO7 GPIO with OE, Ext VREFIN 1 GPI8/SCL I2C SCL/GPI 5 GPIO1 Tolerant GPIO 9 GPO4 GPO 11 GPO6 GPO
Table 2. Functional Pin Description Signal Pin Name Function Input Option Output Option Name
Digital Input without Schmitt Trigger Push-Pull (1x) (2x) GPIO0 General Purpose IO Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) Low-voltage Digital Input - GPIO0 Digital Input without Schmitt Trigger External Clock of Ext CLK Digital Input with Schmitt Trigger - RINGOSC Low-voltage Digital Input Digital Input without Schmitt Trigger - Tolerant General GPIO1 GPIO1 Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) Purpose IO Low-voltage Digital Input - Digital Input without Schmitt Trigger Push-Pull (1x) (2x) GPIO2 General Purpose IO Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) GPIO2 Low-voltage Digital Input - Analog Comparator ACMP1+ Analog - 1 Non-inverting Input Digital Input without Schmitt Trigger Push-Pull (1x) (2x) GPIO3 General Purpose IO Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) GPIO3 Low-voltage Digital Input - Analog Comparator ACMP0+ Analog - 0 Non-inverting Input General Purpose - Push-Pull (1x) (2x) GPO4 GPO4 Output - Open-Drain NMOS (1x) (2x) Digital Input without Schmitt Trigger - Tolerant General GPIO5 Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) Purpose IO with OE Low-voltage Digital Input - GPIO5 Digital Input without Schmitt Trigger External Clock of Ext CLK Digital Input with Schmitt Trigger - LFOSC Low-voltage Digital Input General Purpose - Push-Pull (1x) (2x) GPO6 GPO6 Output - Open-Drain NMOS (1x) (2x) Digital Input without Schmitt Trigger Push-Pull (1x) (2x) General Purpose IO GPIO7 Digital Input with Schmitt Trigger Open-Drain NMOS (1x) (2x) with OE GPIO7 Low-voltage Digital Input - Analog Comparator EXT_VREF Analog - Inverting Input I2C Serial Clock - - SCL SCL/GPI8 Digital Input without Schmitt Trigger - R19DS0184EU0001 Rev. 0.01 Page 3 May 26, 2026
