Datasheet SLG46801 (Renesas) - 4
ManufacturerRenesas
DescriptionGreenPAK Programmable Mixed-Signal IC, VDD Range: 1.71-5.5V, 10 GPIOs, 2 ACMPs, Multi-Time Programmable, I2C in STQFN-12 package
Pages / Page7 / 4 — SLG46801V Advance Datasheet. Signal. Pin Name. Function. Input Option. …
File Format / SizePDF / 201 Kb
SLG46801V Advance Datasheet. Signal. Pin Name. Function. Input Option. Output Option. Name. 3. Specifications. 3.1
SLG46801V Advance Datasheet Signal Pin Name Function Input Option Output Option Name 3 Specifications 3.1
General Purpose Digital Input with Schmitt Trigger - Input Low-voltage Digital Input - I2C Serial Data - - Digital Input without Schmitt Trigger - SDA SDA/GPI9 General Purpose Digital Input with Schmitt Trigger - Input Low-voltage Digital Input - VDD VDD Power Supply - - GND GND Power Supply - -
3. Specifications 3.1 Absolute Maximum Ratings
“ ” v . These are stress ratings only, so functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification are not implied. Exposure to the absolute maximum conditions for extended periods may affect the device reliability.
Parameter Min Max Unit
VDD Voltage to GND -0.5 7.0 V SDA and SCL Voltage to GND -0.5 7.0 V V All GPIO, GPO Pin Voltage to GND -0.5 DD + 0.5, up to V 7.0 Tolerant GPIO Pin Voltage to GND -0.5 7.0 V VDD DC Current - TBD mA GND DC Current - TBD mA GPIO DC Current, Push-pull 1x Output Mode - 12 mA GPIO DC Current, Push-pull 2x Output Mode - 24 mA GPIO DC Current, Open-drain 1x Output Mode - 12 mA GPIO DC Current, Open-drain 2x Output Mode - 24 mA Continuous Power Dissipation (JESD51-7, TA = +25ºC), STQFN-12L, Derate 13 mW / ºC - 1625 mW above TA = +25 ºC Junction Temperature - +150 °C Storage Temperature Range -65 +150 °C
3.2 ESD Ratings Parameter Value Unit
ESD Protection (Human Body Model), ANSI, ESDA, JEDEC JS-001 Standards 3000 V ESD Protection (Charged Device Model), JEDEC JESD22-101 Standard 1500 V R19DS0184EU0001 Rev. 0.01 Page 4 May 26, 2026
