Datasheet PEC16 (Bourns) - 2
ManufacturerBourns
Description16 mm Incremental Encoder
Pages / Page4 / 2 — Applications. PEC16 - 16 mm Incremental Encoder. Product Dimensions. …
File Format / SizePDF / 646 Kb
Applications. PEC16 - 16 mm Incremental Encoder. Product Dimensions. PEC16-2xxxF-Sxxxx. PEC16-4xxxF-Sxxxx
Applications PEC16 - 16 mm Incremental Encoder Product Dimensions PEC16-2xxxF-Sxxxx PEC16-4xxxF-Sxxxx
Applications
Level control, tuning and timer settings in: n Audio-visual equipment n Consumer electric appliances n Radios n Musical instrumentation n Communications equipment
8.0 L1 (.315) 16.0 7.5 (.630) (.295) 7.5 LB F (.295) 1.5 6.0 +0/-0.05 3.1 (.059) 8.3 (.236 +0/-.002) (.122) MOUNTING DIA. (.327) SURFACE 2.6 (.102) 5.0 9.0 DIA. 9.3 (.197) 12.5 M9X0.75 4.5 +0/-0.05 (.354) (.366) 12.5 C (.492) (M9X.030) (.177 +0/-0.02) (.492) E 0.5 +0.4/-0.3 14.4 B 10.0 20.0 25.0 30.0 (.020 +.016/-.012) (.567) D (.394) LM1 17.5 (.688) (.787) (.984) (1.181) 3.5 ± 0.5 3.5 ± 0.5 A SWITCH A B C 7.0 12.0 12.0 1.0 (.138 ± .020) l 5.0 (.138 ± .020) TRAVEL 3.0 +0/-0.1 (.197) (.276) (.472) (.472) (.004) 1.2 +0.1/-0 2.0 2.0 (118 ± .004) 4.0 (.047 +.004/-0) (.079) (.079) DIA. 2.0 (.157) DIA. 5 PLCS. 3.1 (.079) 5.0 5.0 2.1 +0.1/-0 (.122) (.197) (.197) (.083 +.004/-0) 13.5 15.0 20.0 25.0 30.0 L1 (.531) (.591) (.787) (.984) (1.181) 16.1 LB 5.0 7.0 7.0 7.0 (.634) (.197) (.276) (.276) (.276) A CHANNEL A F 7.0 12.0 12.0 12.0 B CHANNEL B (.276) (.472) (.472) (.472) C COMMON
PEC16-4xxxF-Sxxxx
3.5 ± 0.5 8.0 8.3 9.3 16.8 L ± 0.5 (.138 ± .020) (.315) (.327) (.366) 2.1 +0.2/-0 (.661) (.020) SWITCH TRAVEL (.083 +.008/-0) 5.0 7.0 2.0 LB F 16.0 0.5 +0.4/-0.3 2 PLCS. (.197) (.630) (.276) (.079) (.020 +.016/-.012) 2.1 +0.2/-0 6.0 +0/-0.1 (.083 +.008/-0) (.236 +0/-.0002) 2 PLCS. DIA. 10.5 DIA. 10.5 7.0 4.5 (.413) M9XP0.75 4.5 +0/-0.1 (.413) (.276) (.177) (M9XP0.30) (.177 +0/-0.004) A B C 1.8 1.5 9.0 1.2 +0.2/-0 (.354) 4.0 (.071) (.059) (.047 +.008/-0) 10.0 4.5 ± 0.5 2.0 (.157) DIA. 5 PLCS. (.394) (.177 ± .020) (.079) 10.0 3.0 12.5 (.394) (118) (.492) A CHANNEL A DIA. B CHANNEL B C COMMON 1.0 4.0 (.039) (.157) L 15.0 20.0 (.591) (.787) LB 5.0 7.0 (.197) (.276) DIMENSIONS: MM (INCHES) F 7.0 12.0 (.276) (.472) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
