Datasheet PEC16 (Bourns) - 3
ManufacturerBourns
Description16 mm Incremental Encoder
Pages / Page4 / 3 — PEC16 - 16 mm Incremental Encoder. Product Dimensions. PEC16-2xxxF-Nxxxx. …
File Format / SizePDF / 646 Kb
PEC16 - 16 mm Incremental Encoder. Product Dimensions. PEC16-2xxxF-Nxxxx. PEC16-4xxxF-Nxxxx. Panel Hole Detail. Hardware. NUT. WASHER
PEC16 - 16 mm Incremental Encoder Product Dimensions PEC16-2xxxF-Nxxxx PEC16-4xxxF-Nxxxx Panel Hole Detail Hardware NUT WASHER
7.5 L1 (.295) 6.5 16.0 (.256) (.630) 7.5 LB F (.295) 1.5 6.0 +0/-0.05 3.1 (.059) 8.3 (.236 +0/-.002) (.122) MOUNTING DIA. (.327) SURFACE 9.0 DIA. 9.3 12.5 M9X0.75 4.5 +0/-0.05 (.354) (.366) 12.5 C (.492) (M9X.030) (.177 +0/-0.02) (.492) 14.4 B (.567) LM1 17.5 20.0 25.0 30.0 3.5 A ± 0.5 (.688) (.787) 3.5 ± (.984) 0.5 (1.181) A B C 1.0 (.138 ± .020) 7.0 (.138 12.0 ± .020) 12.0 3.0 +0/-0.1 (.004) 1.2 +0.1/-0 l 5.0 2.0(.197) (.276) 2.0 (.472) (.472) (118 ± .004) 4.0 (.047 +.004/-0) (.079) (.079) DIA. 2.0 (.157) DIA. 3 PLCS. 4.1 (.079) 5.0 5.0 2.1 +0.1/-0 (.161) (.197) (.197) (.083 +.004/-0) 13.5 15.0 20.0 25.0 30.0 (.531) L1 (.591) (.787) (.984) (1.181) 16.1 (.634) LB 5.0 7.0 7.0 7.0 (.197) (.276) (.276) (.276) A CHANNEL A B CHANNEL B F 7.0 12.0 12.0 12.0 C COMMON (.276) (.472) (.472) (.472)
PEC16-4xxxF-Nxxxx
6.5 L1 8.3 9.3 (.256) (.327) (.366) 3.5 ± 0.5 16.8 5.0 (.138 ± .020) 16.0 2.0 (.661) (.630) (.197) LB F (.079) 2.0 1.5 6.0 +0/-0.05 A (.079) (.059) (.236 +0/-.002) DIA. 2.1 +0.1/-0 B 10.5 (.083 +.004/-0) (.413) C A B C 4.5 M9X0.75 (.177) (M9X.030) 1.2 +0.1/-0 20.0 25.0 30.0 (.047 +.004/-0) 4.5 +0/-0.05 5.0 10.0 LM1 17.5 9.0 A CHANNEL A 2.7 (.688) (.787) 2.0 (.984) (1.181) DIA. 3 PLCS. (.177 +0/-0.02) (.197) (.394) (.354) DIA. 4.0 B CHANNEL B (.106) (.079) 7.0 12.0 12.0 17.7 C COMMON l 5.0 3.5 ± 0.5 (.157) (.197) (.276) (.472) (.472) (.697) (.138 ± .020) 3.0 +0/-0.1 12.5 (118 ± .004) (.492) DIA. 15.0 20.0 25.0 30.0 L1
(.591) (.787) (.984) (1.181) DIA. LB 5.0 7.0 7.0 7.0 0.75 M9 x (.197) (.276) (.276) (.276) 9.3 +0.2/-0 (.030) (.365 +.008/-.000) F 7.0 12.0 12.0 12.0 (.276) (.472) (.472) (.472) 11.5 ± 0.5 2.0 ± 0.2 (.453 ± .020) (.079 ± .008) DIMENSIONS: MM (INCHES)
NUT
9.0 9.1 ± 0.3 (.358 ± .012) (.354) 3.3 +0.2/-0 15.0 ± 1.0 DIA. (.130 +.008/-.000) (.591 ± .039) DIA. DIA. 0.4 REV. 03/13/23
WASHER
(.016) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
