Datasheet LOC110 (Littelfuse)
ManufacturerLittelfuse
DescriptionSingle Linear Optocoupler
Pages / Page7 / 1 — Not For New Designs. LOC110. Single Linear Optocoupler. Parameter. …
Not For New Designs. LOC110. Single Linear Optocoupler. Parameter. Rating. Units. Description. Features. Approvals. Applications
Datasheet LOC110 Littelfuse
Not For New Designs LOC110 Single Linear Optocoupler
INTEGRATED CIRCUITS DIVISION
Parameter Rating Units Description
LED Operating Range 2 - 10 mA The LOC110 Single Linear Optocoupler features an K3, Transfer Gain 0.668 - 1.179 - infrared LED optically coupled with two photodiodes. Isolation, Input to Output 3750 One feedback (input) photodiode is used to generate Vrms a control signal that provides a servomechanism to the LED drive current, thus compensating
Features
for the LED's nonlinear time and temperature characteristics. The other (output) photodiode • 0.01% Servo Linearity provides an output signal that is linear with respect • THD -87dB Typical to the servo LED current. The product features • Wide Bandwidth (>200kHz) wide bandwidth, high input to output isolation, and • Couples Analog and Digital Signals excellent servo linearity. • High Gain Stability • Low Input/Output Capacitance
Approvals
• Low Power Consumption • UL Recognized Component: File # E76270 • 8-Pin Flatpack or DIP Package • CSA Certified Component: Certificate # 1175739 • Surface Mount and Tape & Reel Versions Available • EN/IEC 60950-1 Certified Component: TUV Certificate # B 13 12 82667 003
Applications Ordering Information
• Modem Transformer Replacement With No
Part Number Description
Insertion Loss LOC110 8-Pin DIP (50/Tube) • Digital Telephone Isolation • Power Supply Feedback Voltage/Current LOC110P 8-Pin Flatpack (50/Tube) • Medical Sensor Isolation LOC110PTR 8-Pin Flatpack (1000/Reel) • Audio Signal Interfacing LOC110S 8-Pin Surface Mount (50/tube) • Isolation of Process Control Transducers LOC110STR 8-Pin Surface Mount (1000/Reel) Each tube or reel will contain only devices of one K3-sorted value. Devices will be individually marked with the letter of their K3 bin.
K3 Sorted Bins NFND
Bin C = 0.668 - 0.732Bin D = 0.733 - 0.805Bin E = 0.806 - 0.886Bin F = 0.887 - 0.974Bin G = 0.975 - 1.072Bin H = 1.073 - 1.179 Devices of any available bin will be shipped.
Pin Configuration
1 8 - LED N/C 2 7 + LED N/C 3 6 C1 C2 4 5 A1 A2 DS-LOC110-R11
www.ixysic.com 1
Document Outline LOC110 xDisclaimer
