Datasheet TL431A, TL431B, NCV431A, NCV431B, SCV431A (ON Semiconductor)
ManufacturerON Semiconductor
DescriptionProgrammable Precision References
Pages / Page23 / 1 — DATA SHEET. Share Feedback. www.onsemi.com. TO-92. LP SUFFIX. LPRA, LPRE, …
File Format / SizePDF / 686 Kb
DATA SHEET. Share Feedback. www.onsemi.com. TO-92. LP SUFFIX. LPRA, LPRE, LPRM,. CASE 29-10. LPRP SUFFIX. PDIP-8. P SUFFIX. CASE 626. Micro8
Datasheet TL431A, TL431B, NCV431A, NCV431B, SCV431A ON Semiconductor
link to page 13 link to page 14 link to page 14
DATA SHEET Share Feedback
Your Opinion Matters
www.onsemi.com
Programmable Precision References TL431A, B Series, Pin 1. Reference 2. Anode NCV431A, B Series, 3. Cathode 1 1 SCV431A 2 2 3 3 STRAIGHT LEAD BENT LEAD The TL431A, B integrated circuits are three-terminal BULK PACK TAPE & REEL AMMO PACK programmable shunt regulator diodes. These monolithic IC voltage
TO-92 TO-92
references operate as a low temperature coefficient zener which is
LP SUFFIX LPRA, LPRE, LPRM,
programmable from Vref to 36 V with two external resistors. These
CASE 29-10 LPRP SUFFIX
devices exhibit a wide operating current range of 1.0 mA to 100 mA
CASE 29-10
with a typical dynamic impedance of 0.22 W. The characteristics of these references make them excellent replacements for zener diodes in
PDIP-8
many applications such as digital voltmeters, power supplies, and op
P SUFFIX CASE 626
amp circuitry. The 2.5 V reference makes it convenient to obtain 8 a stable reference from 5.0 V logic supplies, and since the TL431A, 1
Micro8
E B operates as a shunt regulator, it can be used as either a positive or
DM SUFFIX
negative voltage reference.
CASE 846A
Cathode 1 8 Reference
Features
• N/C 2 7 N/C Programmable Output Voltage to 36 V N/C 3 6 • Anode Voltage Reference Tolerance: ±0.4%, Typ @ 25 °C (TL431B) N/C 4 5 N/C • Low Dynamic Output Impedance, 0.22 W Typical • (Top View) Sink Current Capability of 1.0 mA to 100 mA • Equivalent Full-Range Temperature Coefficient of 50 ppm/°C Typical 8 Cathode 1 8 Reference • Temperature Compensated for Operation over Full Rated Operating 1 2 7 Temperature Range Anode Anode
SOIC-8
3 6 • Low Output Noise Voltage
D SUFFIX
N/C 4 5 N/C •
CASE 751
NCV/SCV Prefixes for Automotive and Other Applications (Top View) Requiring Unique Site and Control Change Requirements; This is an internally modified SOIC-8 package. Pins 2, 3, 6 and AEC-Q100 Qualified and PPAP Capable 7 are electrically common to the die attach flag. This internal • lead frame modification increases power dissipation capability These Devices are Pb-Free, Halogen Free/BFR Free and are RoHS when appropriately mounted on a printed circuit board. This Compliant modified package conforms to all external dimensions of the standard SOIC-8 package.
ORDERING INFORMATION
See detailed ordering and shipping information on page 13 of this data sheet. NOTE: Some of the device on this data sheet have been
DISCONTINUED
. Please refer to the table on page 14
DEVICE MARKING INFORMATION
See general marking information in the device marking section on page 14 of this data sheet. © Semiconductor Components Industries, LLC, 1995
1
Publication Order Number:
November, 2025 − Rev. 45 TL431/D
