Datasheet UF5400, UF5401, UF5402, UF5403, UF5404, UF5405, UF5406, UF5407, UF5408 (Vishay) - 2
ManufacturerVishay
DescriptionSoft Recovery Ultrafast Plastic Rectifier
Pages / Page4 / 2 — UF5400, UF5401, UF5402, UF5403, UF5404, UF5405, UF5406, UF5407, UF5408. …
File Format / SizePDF / 71 Kb
UF5400, UF5401, UF5402, UF5403, UF5404, UF5405, UF5406, UF5407, UF5408. ELECTRICAL CHARACTERISTICS. PARAMETER TEST
UF5400, UF5401, UF5402, UF5403, UF5404, UF5405, UF5406, UF5407, UF5408 ELECTRICAL CHARACTERISTICS PARAMETER TEST
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
PARAMETER TEST CONDITIONS SYMBOL UF5400 UF5401 UF5402 UF5403 UF5404 UF5405 UF5406 UF5407 UF5408 UNIT
Maximum instantaneous 3.0 A VF (1) 1.0 1.7 V forward voltage Maximum DC TA = 25 °C 10 reverse current I μA at rated DC R blocking voltage TA = 100 °C 75 200 Maximum IF = 0.5 A, reverse recovery IR = 1.0 A, TJ = 25 °C trr 50 75 ns time Irr = 0.25 A Typical junction 4.0 V, 1 MHz C capacitance J 45 36 pF
Note
(1) Pulse test: 300 μs pulse width, 1 % duty cycle
THERMAL CHARACTERISTICS
PARAMETER SYMBOL UF5400 UF5401 UF5402 UF5403 UF5404 UF5405 UF5406 UF5407 UF5408 UNIT
RJA (1) 20 Typical thermal resistance °C/W RJL (1) 8.5
Note
(1) Thermal resistance from junction to lead and from junction to ambient with 0.375" (9.5 mm) lead length, both leads attached to heatsink
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
UF5406-E3/54 1.172 54 1400 13" diameter paper tape and reel UF5406-E3/73 1.172 73 1000 Ammo pack packaging
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 3.0 4.5 D = 0.5 D = 0.8 4.0 ent (A) 2.5 D = 0.3 3.5 D = 0.2 Curr (W) D = 1.0 2.0 ss 3.0 D = 0.1 2.5 1.5 d Rectified 2.0 1.0 1.5 T erage Power Lo v A 1.0 0.5 erage Forwar Resistive or Inductive Load v 0.5 D = t /T t p p A 0.375" (9.5 mm) Lead Length 0 0 20 40 60 80 100 120 140 160 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 Ambient Temperature (°C) Average Forward Current (A) Fig. 1 - Maximum Forward Current Derating Curve Fig. 2 - Forward Power Loss Characteristics Revision: 19-Feb-16
2
Document Number: 88756 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
