Datasheet LM4040-N, LM4040-N-Q1 (Texas Instruments) - 4
| Pages / Page | 71 / 4 — LM4040-N,. LM4040-N-Q1. www.ti.com. 5 Pin Configuration and Functions. … |
| Revision | K |
| File Format / Size | PDF / 1.8 Mb |
LM4040-N,. LM4040-N-Q1. www.ti.com. 5 Pin Configuration and Functions. DBZ Package. 3-Pin SOT-23. LP Package. Top View. 3-Pin TO-92
SNOS633K – OCTOBER 2000 – REVISED JUNE 2016
www.ti.com 5 Pin Configuration and Functions DBZ Package 3-Pin SOT-23 LP Package Top View 3-Pin TO-92 Bottom View
1 NC + ± + 3(1) 2 ±
DCK Package 5-Pin SC70 Top View
1 5 ± NC 2 NC(2) 3 4 + NC
Pin Functions PIN I/O DESCRIPTION NAME SOT-23 TO-92 SC70
Anode 2 1 1 O Anode pin, normally grounded Cathode 1 2 3 I/O Shunt Current/Output Voltage NC 3(1) — 2(2) — Must float or connect to anode NC — 3 4, 5 — No connect (1) This pin must be left floating or connected to pin 2. (2) This pin must be left floating or connected to pin 1. 4 Submit Documentation Feedback Copyright © 2000–2016, Texas Instruments Incorporated Product Folder Links: LM4040-N LM4040-N-Q1 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.6 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'I' 6.7 Electrical Characteristics: 2-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' 6.8 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' (AEC Grade 3) 6.9 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'C', 'D', and 'E'; Temperature Grade 'I' (AEC Grade 3) 6.10 Electrical Characteristics: 2.5-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' (AEC Grade 1) 6.11 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.12 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'I' 6.13 Electrical Characteristics: 3-V LM4040-N VR Tolerance Grades 'C', 'D', And 'E'; Temperature Grade 'E' 6.14 Electrical Characteristics: 4.1-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.15 Electrical Characteristics: 4.1-V LM4040-N VR Tolerance Grades 'C' and 'D'; Temperature Grade 'I' 6.16 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.17 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.18 Electrical Characteristics: 5-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'E' 6.19 Electrical Characteristics: 8.2-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.20 Electrical Characteristics: 8.2-V Lm4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.21 Electrical Characteristics: 10-V LM4040-N VR Tolerance Grades 'A' And 'B'; Temperature Grade 'I' 6.22 Electrical Characteristics: 10-V LM4040-N VR Tolerance Grades 'C' And 'D'; Temperature Grade 'I' 6.23 Typical Characteristics 6.23.1 Start-Up Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Shunt Regulator 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curve 9.2.2 4.1-V ADC Application 9.2.2.1 Design Requirements 9.2.2.2 Detailed Design Procedure 9.2.3 Bounded Amplifier 9.2.3.1 Design Requirements 9.2.3.2 Detailed Design Procedure 9.2.4 Protecting Op-Amp Input 9.2.4.1 Design Requirements 9.2.4.2 Detailed Design Procedure 9.2.5 Precision ±4.096-V Reference 9.2.5.1 Design Requirements 9.2.5.2 Detailed Design Procedure 9.2.6 Precision Current Sink/Source 9.2.6.1 Design Requirements 9.2.6.2 Detailed Design Procedure 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Community Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, And Orderable Information 13.1 SOT-23 and SC70 Package Marking Information
