Datasheet TS5A22362 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionTS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability
Pages / Page32 / 1 — TS5A22362. TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative …
RevisionC
TS5A22362. TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability. 1 Features. 3 Description
Datasheet TS5A22362 Texas Instruments, Revision: C
link to page 1 Product Order Technical Tools & Support & Folder Now Documents Software Community
TS5A22362
SCDS364D – JUNE 2015 – REVISED MARCH 2018
TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability 1 Features 3 Description
• Specified Break-Before-Make Switching The TS5A22362 is a bidirectional, 2-channel single- 1 pole double-throw (SPDT) analog switch designed to • Negative Signaling Capability: Maximum Swing operate from 2.3 V to 5.5 V. The device features from –2.75 V to 2.75 V (VCC = 2.75 V) negative signal swing capability that allows signals • Low ON-State Resistance (0.65 Ω Typical) below ground to pass through the switch without • Low Charge Injection distortion. The break-before-make feature prevents signal distortion during the transferring of a signal • Excellent ON-State Resistance Matching from one path to another. Low ON-state resistance, • 2.3-V to 5.5-V Power Supply (VCC) excellent channel-to-channel ON-state resistance • Latch-Up Performance Exceeds 100 mA Per matching, and minimal total harmonic distortion JESD 78, Class II (THD) performance are ideal for audio applications. The 3.00 mm × 3.00 mm DRC package is also • ESD Performance Tested Per JESD 22 available as a nonmagnetic package for medical – 2500-V Human-Body Model imaging application. (A114-B, Class II) – 1500-V Charged-Device Model (C101)
Device Information(1)
– 200-V Machine Model (A115-A)
PART NUMBER PACKAGE BODY SIZE (NOM)
VSON (10) 3.00 mm × 3.00 mm
2 Applications
TS5A22362 DSBGA (10) 1.86 mm × 1.36 mm • Cell Phones VSSOP (10) 3.00 mm × 3.00 mm • PDAs (1) For all available packages, see the orderable addendum at the end of the data sheet. • Portable Instrumentation • Audio Routing • Medical Imaging
Typical Application Schematic OUT+ NC1 Audio OUT– Source 1 COM1 NO1 IN1 Input Select TS5A22362 8-Ω Speaker IN2 NC2 COM2 OUT+ Audio Source 2 OUT– NO2
1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
