Datasheet TS5A22362 (Texas Instruments) - 3
| Description | TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability |
| Pages / Page | 32 / 3 — TS5A22362. www.ti.com. 5 Pin Configuration and Functions. DRC Package. … |
| Revision | C |
| File Format / Size | PDF / 1.4 Mb |
TS5A22362. www.ti.com. 5 Pin Configuration and Functions. DRC Package. DGS Package. 10-Pin VSON. 10-Pin VSSOP. Top View. YZP Package
TS5A22362 www.ti.com
SCDS364D – JUNE 2015 – REVISED MARCH 2018
5 Pin Configuration and Functions DRC Package DGS Package 10-Pin VSON 10-Pin VSSOP Top View Top View
VCC 1 10 NO2 VCC 1 10 NO2 NO1 2 9 COM2 NO1 2 9 COM2 COM1 3 8 NC2 COM1 3 Thermal 8 NC2 Pad NC1 4 7 IN2 NC1 4 7 IN2 IN1 5 6 GND IN1 5 6 GND Not to scale Not to scale The exposed center pad, if used, must be connected as a secondary GND or left electrically open.
YZP Package 10-Pin DSBGA Top View
1 2 3 D IN2 GND IN1 C NC2 NC1 B COM2 COM1 A NO2 VCC NO1 Not to scale
Pin Functions PIN TYPE DESCRIPTION NAME VSON VSSOP DSBGA
VCC 1 1 A2 — Power Supply NO1 2 2 A3 I/O Normally Open (NO) signal path, Switch 1 COM1 3 3 B3 I/O Common signal path, Switch 1 NC1 4 4 C3 I/O Normally Closed (NC) signal path, Switch 1 IN1 5 5 D3 I Digital control pin , Switch 1 GND 6 6 D2 — Ground IN2 7 7 D1 I Digital control pin, Switch 2 NC2 8 8 C1 I/O Normally Closed (NC) signal path, Switch 2 COM2 9 9 B1 I/O Common signal path, Switch 2 NO2 10 10 A1 I/O Normally Open (NO) signal Path, Switch 2 Copyright © 2015–2018, Texas Instruments Incorporated Submit Documentation Feedback 3 Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
