Datasheet TS5A22362 (Texas Instruments) - 6
| Description | TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability |
| Pages / Page | 32 / 6 — TS5A22362. www.ti.com. Electrical Characteristics for 2.5-V Supply … |
| Revision | C |
| File Format / Size | PDF / 1.4 Mb |
TS5A22362. www.ti.com. Electrical Characteristics for 2.5-V Supply (continued). PARAMETER. TEST CONDITIONS. VCC. MIN. TYP. MAX. UNIT
link to page 6 link to page 12 link to page 12 link to page 13 link to page 13 link to page 14 link to page 14 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11
TS5A22362
SCDS364D – JUNE 2015 – REVISED MARCH 2018
www.ti.com Electrical Characteristics for 2.5-V Supply (continued)
VCC = 2.3 V to 2.7 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT
NC, NO, COM V C COM = VCC or GND, COM(ON) See Figure 16 25°C 2.5 V 370 pF ON capacitance Switch ON, f = 10 MHz Digital input CI V capacitance I = VCC or GND See Figure 16 25°C 2.5 V 2.6 pF BW Bandwidth RL = 50 Ω, –3 dB See Figure 18 25°C 2.5 V 17 MHz f = 100 kHz, OISO OFF isolation RL = 50 Ω 25°C 2.5 V –66 dB see Figure 20 f = 100 kHz, XTALK Crosstalk RL = 50 Ω 25°C 2.5 V –75 dB see Figure 21 f = 20 Hz to Total harmonic R THD L = 600 Ω, 20 kHz, 25°C 2.5 V 0.01% distortion CL = 35 pF see Figure 23
Positive V 25°C 0.2 1.1 I COM and VIN = VCC or GND, CC 2.7 V μA supply current VNC and VNO = Floating Full 1.3 V Positive COM = VCC – 5.5 V, ICC V Full 2.7 V 3.3 μA supply current IN = VCC or GND, VNC and VNO = Floating
6.6 Electrical Characteristics for 3.3-V Supply
VCC = 3 V to 3.6 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT ANALOG SWITCH
VCOM, Analog signal V V CC – 5.5 VCC V NO, VNC range VNC or VNO ≤ VCC, 25°C 0.61 0.87 ON-state 1.5 V, COM to NO or NC, Ron 3 V Ω resistance VCC – 5.5 V, see Figure 13 Full 0.97 ICOM = –100 mA ON-state 25°C 0.024 0.13 V COM to NO or NC, ΔR NC or VNO = 1.5 V, on resistance match 3 V Ω I see Figure 13 between channels COM = –100 mA, Full 0.13 V 25°C 0.12 0.46 ON-state NC or VNO ≤ VCC, 1.5 V, COM to NO or NC, Ron(flat) resistance 3 V Ω V see Figure 13 flatness CC – 5.5 V, Full 0.5 ICOM = –100 mA VNC = 3 V, VCC – 5.5 V 25°C –50 50 VCOM = VCC – 5.5 V, 3 V VNO = Open NC, NO COM to NO INC(OFF), OFF leakage or See Figure 14 3.6 V nA INO(OFF) current V Full –375 375 NO = 3 V, VCC – 5.5 V, VCOM = VCC – 5.5 V, 3 V VNC = Open COM to NC COM 25°C –50 50 V COM to NO or NC, I NC and VNO = Floating, COM(ON) ON leakage 3.6 V nA V see Figure 15 current COM = VCC,VCC – 5.5 V Full –375 375
DIGITAL CONTROL INPUTS (IN) (2)
VIH Input logic high 1.4 5.5 Full V VIL Input logic low 0.8 25°C –250 250 IIH, IIL Input leakage current VIN = VCC or 0 3.6 V nA Full –250 250 (1) The algebraic convention, whereby the most negative value is a minimum and the most positive value is a maximum (2) All unused digital inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. 6 Submit Documentation Feedback Copyright © 2015–2018, Texas Instruments Incorporated Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
