Datasheet TS5A22362 (Texas Instruments) - 7
| Description | TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability |
| Pages / Page | 32 / 7 — TS5A22362. www.ti.com. Electrical Characteristics for 3.3-V Supply … |
| Revision | C |
| File Format / Size | PDF / 1.4 Mb |
TS5A22362. www.ti.com. Electrical Characteristics for 3.3-V Supply (continued). PARAMETER. TEST CONDITIONS. VCC. MIN. TYP. MAX. UNIT
link to page 7 link to page 12 link to page 12 link to page 13 link to page 14 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 14 link to page 14 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11
TS5A22362 www.ti.com
SCDS364D – JUNE 2015 – REVISED MARCH 2018
VCC = 3 V to 3.6 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT DYNAMIC
25°C 3.3 V 34 80 V C t COM = VCC, L = 35 pF, ON Turnon time ns R 3 V to L = 300 Ω see Figure 17 Full 120 3.6 V 25°C 3.3 V 19 70 V C t COM = VCC, L = 35 pF, OFF Turnoff time ns R 3 V to L = 300 Ω see Figure 17 Full 70 3.6 V Break-before-make tBBM See Figure 18 25°C 3.3 V 1 7 ns time V C Q GEN = 0, L = 1 nF, C Charge injection 25°C 3.3 V 150 pC RGEN = 0 see Figure 22 CNC(OFF), NC, NO VNC or VNO = VCC or See Figure 16 25°C 3.3 V 70 pF CNO(OFF) OFF capacitance VCC – 5.5 V NC, NO, COM V C COM = VCC or GND, COM(ON) See Figure 16 25°C 3.3 V 370 pF ON capacitance f = 10 MHz Digital input CI V capacitance I = VCC or GND See Figure 16 25°C 3.3 V 2.6 pF Switch ON, BW Bandwidth RL = 50 Ω, –3 dB 25°C 3.3 V 17.5 MHz see Figure 18 f = 100 kHz, OISO OFF isolation RL = 50 Ω 25°C 3.3 V –68 dB see Figure 20 f = 100 kHz, XTALK Crosstalk RL = 50 Ω 25°C 3.3 V –76 dB see Figure 21 Total harmonic R f = 20 Hz to 20 kHz, THD L = 600 Ω, 25°C 3.3 V 0.008% distortion CL = 35 pF see Figure 23
SUPPLY
V 25°C 0.1 1.2 COM and VIN = VCC or GND, 3.6 V μA VNC and VNO = Floating Full 1.3 Positive ICC supply current VCOM = VCC – 5.5 V, VIN = VCC or GND, Full 3.6 V 3.4 μA VNC and VNO = Floating
6.7 Electrical Characteristics for 5-V Supply
VCC = 4.5 V to 5.5 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT ANALOG SWITCH
VCOM, Analog signal V V CC – 5.5 VCC V NO, VNC range V 25°C 0.52 0.74 ON-state NC or VNO = VCC, 1.6 V, COM to NO or NC, Ron V 4.5 V Ω resistance CC = –5.5 V, see Figure 13 I Full 0.83 COM = –100 mA ON-state 25°C 0.04 0.23 V COM to NO or NC, ΔR NC or VNO = 1.6 V, on resistance match 4.5 V Ω I see Figure 13 between channels COM = –100 mA Full 0.30 ON-state VNC or VNO = VCC, 1.6 V, 25°C 0.076 0.46 COM to NO or NC, Ron(flat) resistance VCC = –5.5 V, 4.5 V Ω see Figure 13 flatness I Full 0.5 COM = –100 mA VNC = 4.5 V, VCC – 5.5 V, 25°C –50 50 VCOM = VCC – 5.5 V, 4.5 V, VNO = Open, NC, NO COM to NO INC(OFF), OFF leakage or See Figure 14 5.5 V nA INO(OFF) current V Full –375 375 NO = 4.5 V, VCC – 5.5 V, VCOM = VCC – 5.5 V, 4.5 V, VNC = Open, COM to NC COM 25°C –50 50 V I NC and VNO = Floating, COM(ON) ON leakage See Figure 15 5.5 V nA V current COM = VCC, VCC – 5.5 V Full –375 375 (1) The algebraic convention, whereby the most negative value is a minimum and the most positive value is a maximum Copyright © 2015–2018, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
