Datasheet TS5A22362 (Texas Instruments) - 8
| Manufacturer | Texas Instruments |
| Description | TS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability |
| Pages / Page | 32 / 8 — TS5A22362. www.ti.com. Electrical Characteristics for 5-V Supply … |
| Revision | C |
| File Format / Size | PDF / 1.4 Mb |
TS5A22362. www.ti.com. Electrical Characteristics for 5-V Supply (continued). PARAMETER. TEST CONDITIONS. VCC. MIN. TYP. MAX. UNIT
link to page 8 link to page 12 link to page 12 link to page 13 link to page 14 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 14 link to page 14
TS5A22362
SCDS364D – JUNE 2015 – REVISED MARCH 2018
www.ti.com Electrical Characteristics for 5-V Supply (continued)
VCC = 4.5 V to 5.5 V, TA = –40°C to 85°C (unless otherwise noted) (1)
PARAMETER TEST CONDITIONS TA VCC MIN TYP MAX UNIT DIGITAL CONTROL INPUTS (IN) (2)
VIH Input logic high 2.4 5.5 Full V VIL Input logic low 0.8 Input leakage 25°C –250 250 IIH, IIL V 5.5 V nA current IN = VCC or 0 Full –250 250
DYNAMIC
25°C 5 V 27 80 V C t COM = VCC, L = 35 pF, ON Turnon time ns R 4.5 V to L = 300 Ω see Figure 17 Full 80 5.5 V 25°C 5 V 13 70 V C t COM = VCC, L = 35 pF, OFF Turnoff time ns R 4.5 V to L = 300 Ω see Figure 17 Full 70 5.5 V Break-before-make V C t NC = VNO = VCC/2 L = 35 pF, BBM 25°C 5 V 1 3.5 ns time RL = 300 Ω see Figure 18 V C Q GEN = 0, L = 1 nF, C Charge injection 25°C 5 V 150 pC RGEN = 0 see Figure 22 CNC(OFF), NC, NO VNC or VNO = VCC or See Figure 16 25°C 5 V 70 pF CNO(OFF) OFF capacitance VCC – 5.5 V NC, NO, COM CCOM(ON) V ON capacitance COM = VCC or GND, See Figure 16 25°C 5 V 370 pF Digital input CI V capacitance I = VCC or GND See Figure 16 25°C 5 V 2.6 pF BW Bandwidth RL = 50 Ω See Figure 18 25°C 5 V 18.3 MHz f = 100 kHz, OISO OFF isolation RL = 50 Ω 25°C 5 V –70 dB see Figure 20 f = 100 kHz, XTALK Crosstalk RL = 50 Ω 25°C 5 V –78 dB see Figure 21 Total harmonic R f = 20 Hz to 20 kHz, THD L = 600 Ω, 25°C 5 V 0.009% distortion CL = 35 pF see Figure 23
SUPPLY
V 25°C 0.2 1.3 COM and VIN = VCC or GND, VNC and VNO = Floating Full 3.5 Positive ICC 5.5 V μA supply current VCOM = VCC – 5.5 V, VIN = VCC or GND, Full 5 VNC and VNO = Floating (2) All unused digital inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, SCBA004. 8 Submit Documentation Feedback Copyright © 2015–2018, Texas Instruments Incorporated Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
