Datasheet TS5A22362 (Texas Instruments) - 10
ManufacturerTexas Instruments
DescriptionTS5A22362 0.65-Ω 2-channel SPDT Analog Switches With Negative Signaling Capability
Pages / Page32 / 10 — TS5A22362. www.ti.com. Typical Characteristics (continued). -10. -20. …
RevisionC
TS5A22362. www.ti.com. Typical Characteristics (continued). -10. -20. -30. -40. e Injection (pC). uation (dB) -50. -60. Atten. Char. -70. -80. -90
TS5A22362 www.ti.com Typical Characteristics (continued) -10 -20 -30 -40 e Injection (pC) uation (dB) -50 -60 Atten Char -70 -80 -90
TS5A22362
SCDS364D – JUNE 2015 – REVISED MARCH 2018
500
0
400
-10 -20
300 V = 3.3 V CC
-30
200
-40
100
V = 5 V
g
CC 0
-60
V = 2.5 V
Atten
CC
Char
–100
-70 -80
–200 0 1.8 2.5 3.3 5
-90 1 1000 Voltage (V) Frequency (MHz) Figure 7. Charge Injection (Q Figure 8. Crosstalk (V C) vs VCOM CC = 3.3 V) 0.0091 3.5E-08 0.0081 3.0E-08 0.0071 2.5E-08 0.0061 A) 0.0051 2.0E-08 (μ THD 0.0041 I CC 1.5E-08 0.0031 1.0E-08 0.0021 0.0011 5.0E-09 0.0001 0.0E+00 10 100 1000 10000 100000 0.0 0.5 1.0 1.5 2.5 3.0 3.5 4.0 4.5 5.5 Frequency (Hz) VCC (V) Figure 9. Total Harmonic Distortion vs Frequency Figure 10. Power-Supply Current vs VCC 200 50 180 45
tOFF
160
t
40
ON t
140 35
OFF tON
120 30 (ns) (ns) 100 25 OFF OFF /t 80 /t 20 t ON t ON 60 15 40 10 20 5 0 0 0.0 1.0 2.0 3.0 4.0 5.0 6.0 –40 25 85 Supply Voltage (V) Temperature(°C) Figure 11. tON And tOFF vs Supply Voltage Figure 12. tON And tOFF vs Temperature (2.5-V Supply)
10 Submit Documentation Feedback Copyright © 2015–2018, Texas Instruments Incorporated Product Folder Links: TS5A22362 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics for 2.5-V Supply 6.6 Electrical Characteristics for 3.3-V Supply 6.7 Electrical Characteristics for 5-V Supply 6.8 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Negative Signaling Capacity 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Receiving Notification of Documentation Updates 12.2 Community Resources 12.3 Trademarks 12.4 Electrostatic Discharge Caution 12.5 Glossary 13 Mechanical, Packaging, and Orderable Information
