Datasheet SN74LVC1G74 (Texas Instruments) - 6
ManufacturerTexas Instruments
DescriptionSingle Positive-Edge-Triggered D-Type Flip-Flop with Clear and Preset datasheet
Pages / Page24 / 6 — SN74LVC1G74. www.ti.com. 7.5 Electrical Characteristics. PARAMETER. TEST …
RevisionE
SN74LVC1G74. www.ti.com. 7.5 Electrical Characteristics. PARAMETER. TEST CONDITIONS. VCC. MIN TYP(1). MAX. UNIT. 7.6 Timing Requirements
SN74LVC1G74 www.ti.com 7.5 Electrical Characteristics PARAMETER TEST CONDITIONS VCC MIN TYP(1) MAX UNIT 7.6 Timing Requirements
link to page 8 link to page 8
SN74LVC1G74
SCES794E – OCTOBER 2009 – REVISED JANUARY 2015
over recommended operating free-air temperature range (unless otherwise noted)
IOH = –100 µA 1.65 V to 5.5 V VCC – 0.1 IOH = –4 mA 1.65 V 1.2 IOH = –8 mA 2.3 V 1.9 VOH V IOH = –16 mA 2.4 3 V IOH = –24 mA 2.3 IOH = –32 mA 4.5 V 3.8 IOL = 100 µA 1.65 V to 5.5 V 0.1 IOL = 4 mA 1.65 V 0.45 IOL = 8 mA 2.3 V 0.3 VOL V IOL = 16 mA 0.4 3 V IOL = 24 mA 0.55 IOL = 32 mA 4.5 V 0.55 Data or II VI = 5.5 V or GND 0 to 5.5 V ±5 µA control inputs Ioff VI or VO = 5.5 V 0 ±10 µA ICC VI = 5.5 V or GND, IO = 0 1.65 V to 5.5 V 10 µA ΔICC One input at VCC – 0.6 V, Other inputs at VCC or GND 3 V to 5.5 V 500 µA Ci VI = VCC or GND 3.3 V 5 pF (1) All typical values are at VCC = 3.3 V, TA = 25°C.
over recommended operating free-air temperature range (unless otherwise noted) (see Figure 3)
–40°C to 85°C –40°C to 125°C FROM TO PARAMETER VCC = 1.8 V VCC = 2.5 V VCC = 3.3 V VCC = 5 V VCC = 3.3 V VCC = 5 V UNIT (INPUT) (OUTPUT) MIN MAX MIN MAX MIN MAX MIN MAX MIN MAX MIN MAX
fclock 80 175 175 200 175 200 MHz CLK 6.2 2.7 2.7 2 2.7 2 tw ns PRE or CLR low 6.2 2.7 2.7 2 2.7 2 Data 2.9 1.7 1.3 1.1 1.3 1.1 tsu ns PRE or CLR inactive 1.9 1.4 1.2 1 1.2 1.2 th 0 0.3 1.2 0.5 1.2 0.5 ns
7.7 Switching Characteristics
fmax 80 175 175 200 175 200 MHz Q 4.8 13.4 2.2 7.1 2.2 5.9 1.4 4.1 2.2 7.9 1.4 6.1 CLK Q 6 14.4 3 7.7 2.6 6.2 1.6 4.4 2.6 8.2 1.6 6.4 tpd ns PRE or CLR Q or Q 4.4 12.9 2.3 7 1.7 5.9 1.6 4.1 1.7 7.9 1.6 6.1 low 6 Submit Documentation Feedback Copyright © 2009–2015, Texas Instruments Incorporated Product Folder Links: SN74LVC1G74 Document Outline 1 Features 2 Applications 3 Description 4 Simplified Schematic Table of Contents 5 Revision History 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 ESD Ratings 7.3 Recommended Operating Conditions 7.4 Thermal Information 7.5 Electrical Characteristics 7.6 Timing Requirements 7.7 Switching Characteristics 7.8 Operating Characteristics 7.9 Typical Characteristics 8 Parameter Measurement Information 9 Detailed Description 9.1 Overview 9.2 Functional Block Diagram 9.3 Feature Description 9.4 Device Functional Modes 10 Application and Implementation 10.1 Application Information 10.2 Typical Power Button Circuit 10.2.1 Design Requirements 10.2.2 Detailed Design Procedure 10.2.3 Application Curves 11 Power Supply Recommendations 12 Layout 12.1 Layout Guidelines 12.2 Layout Example 13 Device and Documentation Support 13.1 Trademarks 13.2 Electrostatic Discharge Caution 13.3 Glossary 14 Mechanical, Packaging, and Orderable Information
