Datasheet OPA2333, OPA333 (Texas Instruments) - 8
| Manufacturer | Texas Instruments |
| Description | OPAx333 1.8-V, microPower, CMOS Operational Amplifiers, Zero-Drift |
| Pages / Page | 45 / 8 — OPA333. , OPA2333. www.ti.com. 6.7 Typical Characteristics. Table 1. List … |
| Revision | E |
| File Format / Size | PDF / 2.2 Mb |
OPA333. , OPA2333. www.ti.com. 6.7 Typical Characteristics. Table 1. List of Typical Characteristics. TITLE. FIGURE
link to page 8 link to page 8 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11
OPA333 , OPA2333
SBOS351E – MARCH 2006 – REVISED DECEMBER 2015
www.ti.com 6.7 Typical Characteristics Table 1. List of Typical Characteristics TITLE FIGURE
Offset Voltage Production Distribution Figure 1 Offset Voltage Drift Production Distribution Figure 2 Open-Loop Gain vs Frequency Figure 3 Common-Mode Rejection Ratio vs Frequency Figure 4 Power-Supply Rejection Ratio vs Frequency Figure 5 Output Voltage Swing vs Output Current Figure 6 Input Bias Current vs Common-Mode Voltage Figure 7 Input Bias Current vs Temperature Figure 8 Quiescent Current vs Temperature Figure 9 Large-Signal Step Response Figure 10 Small-Signal Step Response Figure 11 Positive Overvoltage Recovery Figure 12 Negative Overvoltage Recovery Figure 13 Settling Time vs Closed-Loop Gain Figure 14 Small-Signal Overshoot vs Load Capacitance Figure 15 0.1-Hz to 10-Hz Noise Figure 16 Current and Voltage Noise Spectral Density vs Frequency Figure 17 At TA = 25°C, VS = 5 V, and CL = 0 pF, unless otherwise noted. opulation opulation P P 0 9 8 7 6 5 4 3 2 1 0 1 2 3 4 5 6 7 8 9 10 - - - - - - - - - 10 0.0025 0.0050 0.0075 0.0100 0.0125 0.0150 0.0175 0.0200 0.0225 0.0250 0.0275 0.0300 0.0325 0.0350 0.0375 0.0400 0.0425 0.0450 0.0475 0.0500 - Offset Voltage ( Offset Voltage Drift (mV/ C) ° mV)
Figure 2. Offset Voltage Drift Production Distribution Figure 1. Offset Voltage Production Distribution
8 Submit Documentation Feedback Copyright © 2006–2015, Texas Instruments Incorporated Product Folder Links: OPA333 OPA2333 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA333 6.5 Thermal Information: OPA2333 6.6 Electrical Characteristics 6.7 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Operating Voltage 7.3.2 Input Voltage 7.3.3 Internal Offset Correction 7.3.4 Achieving Output Swing to the Op Amp Negative Rail 7.3.5 DFN Package 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 High-Side Voltage-to-Current (V-I) Converter 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curve 8.2.2 Precision, Low-Level Voltage-to-Current (V-I) Converter 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 8.2.2.3 Application Curves 8.2.3 Composite Amplifier 8.2.3.1 Design Requirements 8.2.3.2 Detailed Design Procedure 8.2.3.3 Application Curve 8.3 System Examples 8.3.1 Temperature Measurement Application 8.3.2 Single Operational Amplifier Bridge Amplifier Application 8.3.3 Low-Side Current Monitor Application 8.3.4 Other Applications 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 General Layout Guidelines 10.1.2 DFN Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Community Resources 11.5 Trademarks 11.6 Electrostatic Discharge Caution 11.7 Glossary 12 Mechanical, Packaging, and Orderable Information
