Datasheet SN74LVC2G14 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionDual Schmitt-Trigger Inverter
Pages / Page24 / 1 — SN74LVC2G14. SN74LVC2G14 Dual Schmitt-Trigger Inverter. 1 Features. 3 …
RevisionO
SN74LVC2G14. SN74LVC2G14 Dual Schmitt-Trigger Inverter. 1 Features. 3 Description. Device Information(1). PART NUMBER. PACKAGE
Datasheet SN74LVC2G14 Texas Instruments, Revision: O
link to page 1 Product Sample & Technical Tools & Support & Reference Folder Buy Documents Software Community Design
SN74LVC2G14
SCES200O – APRIL 1999 – REVISED AUGUST 2015
SN74LVC2G14 Dual Schmitt-Trigger Inverter 1 Features 3 Description
This dual Schmitt-trigger inverter is designed for • Available in the TI NanoFree™ Package 1 1.65-V to 5.5-V VCC operation. • Supports 5-V VCC Operation NanoFree™ package technology is a major • Inputs Accept Voltages to 5.5 V breakthrough in IC packaging concepts, using the die • Max tpd of 5.4 ns at 3.3 V as the package. • Low-Power Consumption, 10-μA Maximum ICC The SN74LVC2G14 device contains two inverters • ±24-mA Output Drive at 3.3 V and performs the Boolean function Y = A. The device • Typical VOLP (Output Ground Bounce) functions as two independent inverters, but because <0.8 V at V of Schmitt action, it may have different input threshold CC = 3.3 V, TA = 25°C levels for positive-going (VT+) and negative-going • Typical VOHV (Output VOH Undershoot) (VT–) signals. >2 V at VCC = 3.3 V, TA = 25°C This device is fully specified for partial-power-down • Ioff Supports Live Insertion, Partial-Power-Down applications using Ioff. The Ioff circuitry disables the Mode, and Back-Drive Protection outputs, preventing damaging current backflow • Support Translation Down through the device when it is powered down. (5 V to 3.3 V; 3.3 V to 1.8 V) • Latch-Up Performance Exceeds 100 mA
Per JESD 78, Class II
PART NUMBER PACKAGE BODY SIZE (NOM)
SN74LVC2G14DBV SOT-23 (6) 2.90 mm × 1.60 mm
2 Applications
SN74LVC2G14DCK SC70 (6) 2.00 mm × 1.25 mm SN74LVC2G14YZP DSBGA (6) 1.41 mm × 0.91 mm • Body Control Modules • Engine Control Modules (1) For all available packages, see the orderable addendum at the end of the data sheet. • Arcade, Casino, and Gambling Machines • Servers and High-Performance Computing • EPOS, ECR, and Cash Drawer • Routers • Desktop PC
Block Diagram 1 6 1A 1Y 3 4 2A 2Y
1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Switching Characteristics, –40°C to 85°C 6.7 Switching Characteristics, –40°C to 125°C 6.8 Operating Characteristics 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Support Translation Down (5 V to 3.3 V; 3.3 V to 1.8 V) 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Community Resources 12.2 Trademarks 12.3 Electrostatic Discharge Caution 12.4 Glossary 13 Mechanical, Packaging, and Orderable Information
