Datasheet SN74LVC2G14 (Texas Instruments) - 5
| Description | Dual Schmitt-Trigger Inverter |
| Pages / Page | 24 / 5 — SN74LVC2G14. www.ti.com. 6.4 Thermal Information. THERMAL METRIC(1). DBV … |
| Revision | O |
| File Format / Size | PDF / 1.1 Mb |
SN74LVC2G14. www.ti.com. 6.4 Thermal Information. THERMAL METRIC(1). DBV (SOT23). DCK (SC70). YZP (DSBGA). UNIT. 6 PINS
SN74LVC2G14 www.ti.com
SCES200O – APRIL 1999 – REVISED AUGUST 2015
6.4 Thermal Information SN74LVC2G14 THERMAL METRIC(1) DBV (SOT23) DCK (SC70) YZP (DSBGA) UNIT 6 PINS 6 PINS 6 PINS
RθJA Junction-to-ambient thermal resistance 215 259 139 °C/W RθJC(top) Junction-to-case (top) thermal resistance 55 87 18 °C/W RθJB Junction-to-board thermal resistance 57 89 N/A °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953.
6.5 Electrical Characteristics
over recommended operating free-air temperature range (unless otherwise noted)
–40°C to 85°C –40°C to 125°C PARAMETER TEST CONDITIONS VCC UNIT MIN TYP(1) MAX MIN TYP(1) MAX
1.65 V 0.7 1.4 0.7 1.4 2.3 V 1 1.7 1 1.7 VT+ Positive-going input 3 V 1.3 2.2 1.3 2.2 V threshold voltage 4.5 V 1.9 3.1 1.9 3.1 5.5 V 2.2 3.7 2.2 3.7 1.65 V 0.3 0.7 0.3 0.7 2.3 V 0.4 1 0.4 1 VT– Negative-going input 3 V 0.6 1.3 0.6 1.3 V threshold voltage 4.5 V 1.1 2 1.1 2 5.5 V 1.4 2.5 1.4 2.5 1.65 V 0.3 0.8 0.3 0.8 2.3 V 0.4 0.9 0.4 0.9 ΔVT Hysteresis 3 V 0.4 1.1 0.4 1.1 V (VT+ – VT–) 4.5 V 0.6 1.3 0.6 1.3 5.5 V 0.7 1.4 0.7 1.4 IOH = –100 μA 1.65 V to 4.5 V VCC – 0.1 VCC – 0.1 IOH = –4 mA 1.65 V 1.2 1.2 IOH = –8 mA 2.3 V 1.9 1.9 VOH V IOH = –16 mA 3 V 2.4 2.4 IOH = –24 mA 3 V 2.3 2.3 IOH = –32 mA 4.5 V 3.8 3.8 IOL = 100 μA 1.65 V to 4.5 V 0.1 0.1 IOL = 4 mA 1.65 V 0.45 0.45 IOL = 8 mA 2.3 V 0.3 0.3 VOL V IOL = 16 mA 3 V 0.4 0.4 IOL = 24 mA 3 V 0.55 0.55 IOL = 32 mA 4.5 V 0.55 0.55 II A input VI = 5.5 V or GND 0 to 5.5 V ±5 ±5 μA Ioff VI or VO = 5.5 V 0 ±10 ±10 μA ICC VI = 5.5 V or GND, IO = 0 1.65 V to 5.5 V 10 10 μA One input at VCC – 0.6 V, ΔICC 3 V to 5.5 V 500 500 μA Other inputs at VCC or GND CI VI = VCC or GND 3.3 V 4 pF (1) All typical values are at VCC = 3.3 V, TA = 25°C. Copyright © 1999–2015, Texas Instruments Incorporated Submit Documentation Feedback 5 Product Folder Links: SN74LVC2G14 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Switching Characteristics, –40°C to 85°C 6.7 Switching Characteristics, –40°C to 125°C 6.8 Operating Characteristics 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Support Translation Down (5 V to 3.3 V; 3.3 V to 1.8 V) 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Community Resources 12.2 Trademarks 12.3 Electrostatic Discharge Caution 12.4 Glossary 13 Mechanical, Packaging, and Orderable Information
