Datasheet SN74LVC2G14 (Texas Instruments) - 6
| Description | Dual Schmitt-Trigger Inverter |
| Pages / Page | 24 / 6 — SN74LVC2G14. www.ti.com. 6.6 Switching Characteristics, –40°C to 85°C. … |
| Revision | O |
| File Format / Size | PDF / 1.1 Mb |
SN74LVC2G14. www.ti.com. 6.6 Switching Characteristics, –40°C to 85°C. VCC = 1.8 V. VCC = 2.5 V. VCC = 3.3 V. VCC = 5 V. FROM. ± 0.15 V
link to page 7 link to page 7
SN74LVC2G14
SCES200O – APRIL 1999 – REVISED AUGUST 2015
www.ti.com 6.6 Switching Characteristics, –40°C to 85°C
over recommended operating free-air temperature range (unless otherwise noted) (see Figure 3)
VCC = 1.8 V VCC = 2.5 V VCC = 3.3 V VCC = 5 V FROM TO ± 0.15 V ± 0.2 V ± 0.3 V ± 0.5 V PARAMETER UNIT (INPUT) (OUTPUT) MIN MAX MIN MAX MIN MAX MIN MAX
tpd A Y 3.9 9.5 1.9 5.7 2 5.4 1.5 4.3 ns
6.7 Switching Characteristics, –40°C to 125°C
tpd A Y 3.9 10.5 1.9 6.5 2 6 1.5 4.7 ns
6.8 Operating Characteristics
TA = 25°C
VCC = 1.8 V VCC = 2.5 V VCC = 3.3 V VCC = 5 V PARAMETER TEST CONDITIONS UNIT TYP TYP TYP TYP
Cpd Power dissipation capacitance f = 10 MHz 16 17 18 21 pF
6.9 Typical Characteristics
8 TPD 7 6 ) 5 s) (n 4 D P TPD (ns T 3 2 1 0 0 1 2 3 4 5 6 VCC (V) D002 Temperature (°C)
Figure 2. TPD Across VCC at 25°C Figure 1. TPD Across Temperature at 3.3 V VCC
6 Submit Documentation Feedback Copyright © 1999–2015, Texas Instruments Incorporated Product Folder Links: SN74LVC2G14 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Switching Characteristics, –40°C to 85°C 6.7 Switching Characteristics, –40°C to 125°C 6.8 Operating Characteristics 6.9 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Support Translation Down (5 V to 3.3 V; 3.3 V to 1.8 V) 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Community Resources 12.2 Trademarks 12.3 Electrostatic Discharge Caution 12.4 Glossary 13 Mechanical, Packaging, and Orderable Information
