Datasheet TPS40210, TPS40211 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionTPS4021x 4.5-V to 52-V Input Current Mode Boost Controller
Pages / Page52 / 1 — TPS40210. , TPS40211. TPS4021x 4.5-V to 52-V Input Current Mode Boost …
RevisionF
TPS40210. , TPS40211. TPS4021x 4.5-V to 52-V Input Current Mode Boost Controller. 1 Features. 3 Description
Datasheet TPS40210, TPS40211 Texas Instruments, Revision: F
link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 1 Product Sample & Technical Tools & Support & Folder Buy Documents Software Community
TPS40210 , TPS40211
SLUS772F – MARCH 2008 – REVISED MARCH 2015
TPS4021x 4.5-V to 52-V Input Current Mode Boost Controller 1 Features 3 Description
• For Boost, Flyback, SEPIC, LED Drive Apps The TPS40210 and TPS40211 are wide-input voltage 1 (4.5 V to 52 V), nonsynchronous boost controllers. • Wide Input Operating Voltage: 4.5 V to 52 V They are suitable for topologies which require a • Adjustable Oscillator Frequency grounded source N-channel FET including boost, • Fixed Frequency Current Mode Control flyback, SEPIC and various LED Driver applications. The device features include programmable soft-start, • Internal Slope Compensation overcurrent protection with automatic retry and • Integrated Low-Side Driver programmable oscillator frequency. Current mode • Programmable Closed-Loop Soft-Start control provides improved transient response and • Overcurrent Protection simplified loop compensation. The main difference between the two parts is the reference voltage to • External Synchronization Capable which the error amplifier regulates the FB pin. • Reference 700 mV (TPS40210), 260 mV (TPS40211)
Device Information(1)
• Low Current Disable Function
PART NUMBER PACKAGE BODY SIZE (NOM)
• Create a Custom Design Using the TPS4021x TPS40210 HVSSOP (10) 3.05 mm x 4.98 mm with the WEBENCH Power Designer TPS40211 VSON (10) 3.10 mm x 3.10 mm (1) For all available packages, see the orderable addendum at
2 Applications
the end of the datasheet. • LED Lighting • Industrial Control Systems • Battery Powered Systems
Simplified Schematic
VIN TPS40210 VOUT 1 RC VDD 10 2 SS BP 9 3 DIS/EN GDRV 8 4 COMP ISNS 7 RSENSE 5 FB 6 GND UDG-07110 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Soft-Start 7.3.2 BP Regulator 7.3.3 Shutdown (DIS/EN Pin) 7.3.4 Minimum On-Time and Off-Time Considerations 7.3.5 Setting the Oscillator Frequency 7.3.6 Synchronizing the Oscillator 7.3.7 Current Sense and Overcurrent 7.3.8 Current Sense and Sub-Harmonic Instability 7.3.9 Current Sense Filtering 7.3.10 Control Loop Considerations 7.3.11 Gate Drive Circuit 7.3.12 TPS40211 7.4 Device Functional Modes 7.4.1 Operation Near Minimum Input Voltage 7.4.2 Operation With DIS/EN Pin 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 12-V to 24-V Nonsynchronous Boost Regulator 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 12-V Input, 700-mA LED Driver, Up to 35-V LED String 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Third-Party Products Disclaimer 11.1.2 Related Devices 11.2 Documentation Support 11.2.1 Custom Design with WEBENCH Tools 11.2.2 Receiving Notification of Documentation Updates 11.2.3 References 11.3 Related Links 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
