Datasheet TPS40210, TPS40211 (Texas Instruments) - 8
ManufacturerTexas Instruments
DescriptionTPS4021x 4.5-V to 52-V Input Current Mode Boost Controller
Pages / Page52 / 8 — TPS40210,. TPS40211. www.ti.com. Typical Characteristics (continued). …
RevisionF
TPS40210,. TPS40211. www.ti.com. Typical Characteristics (continued). 180. 300. 160. – t. n 250. n –. rre. 140. C e. rre 120. rc 200. ia 100. B k
TPS40210, TPS40211 www.ti.com Typical Characteristics (continued) 180 300 160 – t n 250 n – rre 140 C e rre 120 rc 200 ia 100 B k
TPS40210, TPS40211
SLUS772F – MARCH 2008 – REVISED MARCH 2015
www.ti.com Typical Characteristics (continued) 180 300 A
m
160 – t A n 250 n – rre 140 t u n C e rre 120 rc 200 u u C o s S ia 100 n B k tio 150 c a a 80 s b n e d e p e m F 60 o 100 – C ) – B 40 ) (F C R I IB 50 (S P 20 M O I C 0 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 T – Junction Temperature – ° C T – Junction Temperature – ° C J J Figure 13. FB Bias Current vs Junction Temperature Figure 14. Compensation Source Current vs Junction Temperature 300 5 A m 4 – t 250 n % 3 rre – u e C g 2 k 200 n a in h S C 1 n e g tio a 150 lta 0 s o n e V p y -1 m lle o 100 a C V -2 – – ) Y K L N V V -3 (S 50 P M O -4 I C 0 -5 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 T – Junction Temperature – ° C T – Junction Temperature – ° C J J Figure 15. Compensation Sink Current vs Junction Figure 16. Valley Voltage Change vs Junction Temperature Temperature 8.8 1.10 1.09 V 8.6 m – I = 0 mA 1.08 LOAD ld V o – 8.4 h s e 1.07 g re h lta T o 1.06 n V 8.2 r -O to rn 1.05 la u u T g 8.0 e N 1.06 R /E – IS P 1.03 7.8 D B I = 5 mA LOAD – V ) N1.02 (E 7.6 IS D V 1.01 7.4 1.00 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 T – Junction Temperature – ° C T – Junction Temperature – ° C J J Figure 17. Regulator Voltage vs Junction Temperature Figure 18. DIS/EN Turn-On Threshold vs Junction Temperature
8 Submit Documentation Feedback Copyright © 2008–2015, Texas Instruments Incorporated Product Folder Links: TPS40210 TPS40211 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Soft-Start 7.3.2 BP Regulator 7.3.3 Shutdown (DIS/EN Pin) 7.3.4 Minimum On-Time and Off-Time Considerations 7.3.5 Setting the Oscillator Frequency 7.3.6 Synchronizing the Oscillator 7.3.7 Current Sense and Overcurrent 7.3.8 Current Sense and Sub-Harmonic Instability 7.3.9 Current Sense Filtering 7.3.10 Control Loop Considerations 7.3.11 Gate Drive Circuit 7.3.12 TPS40211 7.4 Device Functional Modes 7.4.1 Operation Near Minimum Input Voltage 7.4.2 Operation With DIS/EN Pin 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 12-V to 24-V Nonsynchronous Boost Regulator 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 12-V Input, 700-mA LED Driver, Up to 35-V LED String 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Third-Party Products Disclaimer 11.1.2 Related Devices 11.2 Documentation Support 11.2.1 Custom Design with WEBENCH Tools 11.2.2 Receiving Notification of Documentation Updates 11.2.3 References 11.3 Related Links 11.4 Trademarks 11.5 Electrostatic Discharge Caution 11.6 Glossary 12 Mechanical, Packaging, and Orderable Information
