Datasheets - Solid State Relays (SSR) Schneider Electric - 5
Subsection: "Solid State Relays (SSR)"
Manufacturer: "Schneider Electric"
Search results: 140 Output: 81-100
View: List / Images
  1. Datasheet 8501KF12V20 - Schneider Electric POWER RELAY, 240  VAC, 10  A, DPDT
    Part Number: 8501KF12V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, DPDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: DPDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  2. Datasheet 8501KP12P14V20 - Schneider Electric POWER RELAY, 240  VAC, 10  A, DPDT
    Part Number: 8501KP12P14V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, DPDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: DPDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  1. Datasheet 8501KP12V24 - Schneider Electric POWER RELAY, 240  VAC, 10  A, DPDT
    Part Number: 8501KP12V24 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, DPDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 240 V Contact Configuration: DPDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  2. Part Number: 8501KP13V20 Manufacturer: Schneider Electric Description: Power Relay Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: 3PDT Contact Current Max: 12 A Contact Voltage AC Nom: 240 V Contact Voltage DC Nom: ...
  3. Datasheet 8501KPD12P14V53 - Schneider Electric POWER RELAY, 240  VAC, 10  A, DPDT
    Part Number: 8501KPD12P14V53 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, DPDT Specifications: Coil Type: DC Coil Voltage VDC Nom: 24 V Contact Configuration: DPDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  4. Datasheet 8501RS14V20 - Schneider Electric POWER RELAY, 240  VAC, 10  A, 4PDT
    Part Number: 8501RS14V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, 4PDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: 4PDT Contact Current Max: 5 A Contact Voltage AC Nom: 240 V ...
  5. Datasheet 8501RS41V20 - Schneider Electric POWER RELAY, 240  VAC, 15  A, SPDT
    Part Number: 8501RS41V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 15 A, SPDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: SPDT Contact Current Max: 15 A Contact Voltage AC Nom: 240 V ...
  6. Datasheet 8501RS42V20 - Schneider Electric POWER RELAY, 240  VAC, 10  A, DPDT
    Part Number: 8501RS42V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, DPDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: DPDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  7. Datasheet 8501RS44P14V20 - Schneider Electric POWER RELAY, 240  VAC, 10  A, 4PDT
    Part Number: 8501RS44P14V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 10 A, 4PDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: 4PDT Contact Current Max: 10 A Contact Voltage AC Nom: 240 V ...
  8. Datasheet 8501RS4V20 - Schneider Electric POWER RELAY, 240  VAC, 3  A, 4PDT
    Part Number: 8501RS4V20 Manufacturer: Schneider Electric Description: POWER RELAY, 240 VAC, 3 A, 4PDT Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: 4PDT Contact Current Max: 3 A Contact Voltage AC Nom: 240 V ...
  9. Part Number: 8501RSD41V53 Manufacturer: Schneider Electric Description: POWER RELAY, 28 V DC, 15 A, SPDT Specifications: Coil Type: DC Coil Voltage VDC Nom: 24 V Contact Configuration: SPDT Contact Current Max: 15 A Contact Voltage DC Nom: 28 V ...
  10. Part Number: CAD50G7 Manufacturer: Schneider Electric Description: Industrial Control Relay Download Data Sheet Specifications: Coil Type: AC Coil Voltage VAC Nom: 120 V Contact Configuration: 5PST-NO Contact Current Max: 10 A Contact Voltage AC ...
  11. Part Number: RXM4GB2P7 Manufacturer: Schneider Electric Description: RELAY, 4 CO, 230 VAC, W/ LED RoHS: Yes
  12. Part Number: RXM4GB2BD Manufacturer: Schneider Electric Description: RELAY, 4 CO, 24 V DC, W/ LED RoHS: Yes
  13. Part Number: RXM4AB2P7TQ Manufacturer: Schneider Electric Description: RELAY, 4 CO, 230 VAC, W/ LED RoHS: Yes
  14. Part Number: RXM4AB2P7 Manufacturer: Schneider Electric Description: RELAY, 4 CO, 230 VAC, W/ LED RoHS: Yes
  15. Part Number: RXM4AB2JD Manufacturer: Schneider Electric Description: RELAY, 4 CO, 12 V DC, W/ LED RoHS: Yes
  16. Part Number: RXM4AB2F7 Manufacturer: Schneider Electric Description: RELAY, 4 CO, 120 VAC, W/ LED RoHS: Yes
  17. Part Number: RXM4AB2ED Manufacturer: Schneider Electric Description: RELAY, 4 CO, 48 V DC, W/ LED RoHS: Yes
  18. Part Number: RXM4AB2E7 Manufacturer: Schneider Electric Description: RELAY, 4 CO, 48 VAC, W/ LED RoHS: Yes
Sort by: relevance / date
