Datasheets - Current Sense Amplifiers Linear Technology - 3
Subsection: "Current Sense Amplifiers"
Manufacturer: "Linear Technology"
Search results: 67 Output: 41-60
View: List / Images
  1. Datasheet LT1999IMS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, MSOP8
    Part Number: LT1999IMS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, MSOP8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  2. Datasheet LT1999IMS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, MSOP8
    Part Number: LT1999IMS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, MSOP8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  1. Datasheet LT1999HS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, SOIC8
    Part Number: LT1999HS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, SOIC8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  2. Datasheet LT1999HS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999HS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  3. Datasheet LT1999HS8-10 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999HS8-10 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  4. Datasheet LT1999HMS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, MSOP8
    Part Number: LT1999HMS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, MSOP8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  5. Datasheet LT1999HMS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, MSOP8
    Part Number: LT1999HMS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, MSOP8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  6. Datasheet LT1999CS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, SOIC8
    Part Number: LT1999CS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, SOIC8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  7. Datasheet LT1999CS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999CS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  8. Datasheet LT1999CS8-10 - Linear Technology IC, CURR SENS AMP, 2 MHz, SOIC8
    Part Number: LT1999CS8-10 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, SOIC8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  9. Datasheet LT1999CMS8-50 - Linear Technology IC, CURR SENS AMP, 1.2 MHz, MSOP8
    Part Number: LT1999CMS8-50 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 1.2 MHz, MSOP8 Specifications: Bandwidth: 1.2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output ...
  10. Datasheet LT1999CMS8-20 - Linear Technology IC, CURR SENS AMP, 2 MHz, MSOP8
    Part Number: LT1999CMS8-20 Manufacturer: Linear Technology Description: IC, CURR SENS AMP, 2 MHz, MSOP8 Specifications: Bandwidth: 2 MHz CMRR: 120 dB Input Bias Current: 137.5 µA Input Offset Voltage: 1.5 mV Number of Amplifiers: 2 Output Current ...
  11. Datasheet LTC6104IMS8 - Linear Technology AMP, CURRENT SENSE, HIGH VOLT, SMD
    Part Number: LTC6104IMS8 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, HIGH VOLT, SMD Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 200 kHz Base Number: 6104 Bias Current: 170 nA Gain Bandwidth: 200 ...
  12. Datasheet LTC6104HMS8 - Linear Technology AMP, CURRENT SENSE, HIGH VOLT, SMD
    Part Number: LTC6104HMS8 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, HIGH VOLT, SMD Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 200 kHz Base Number: 6104 Bias Current: 170 nA Gain Bandwidth: 200 ...
  13. Datasheet LTC6104CMS8 - Linear Technology AMP, CURRENT SENSE, HIGH VOLT, SMD
    Part Number: LTC6104CMS8 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE, HIGH VOLT, SMD Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 200 kHz Base Number: 6104 Bias Current: 170 nA Gain Bandwidth: 200 ...
  14. Datasheet LTC6103IMS8 - Linear Technology AMP, CURRENT SENSE DUAL, SMD, MSOP8
    Part Number: LTC6103IMS8 Manufacturer: Linear Technology Description: AMP, CURRENT SENSE DUAL, SMD, MSOP8 Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 140 kHz Base Number: 6103 Bias Current: 170 nA Gain Bandwidth: 140 ...
  15. Datasheet LTC6103HMS8 - Linear Technology IC, CURRENT SENSE AMP, DUAL, 8MSOP
    Part Number: LTC6103HMS8 Manufacturer: Linear Technology Description: IC, CURRENT SENSE AMP, DUAL, 8MSOP Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 140 kHz Base Number: 6103 Bias Current: 100 nA Gain Bandwidth: 140 ...
  16. Datasheet LTC6103CMS8 - Linear Technology IC, CURRENT SENSE AMP, DUAL, 8MSOP
    Part Number: LTC6103CMS8 Manufacturer: Linear Technology Description: IC, CURRENT SENSE AMP, DUAL, 8MSOP Download Data Sheet Specifications: Amplifier Case Style: MSOP Bandwidth: 140 kHz Base Number: 6103 Bias Current: 100 nA Gain Bandwidth: 140 ...
  17. Datasheet LTC6101HVAHMS8 - Linear Technology IC, SM, OP AMP, CURRENT SENSE
    Part Number: LTC6101HVAHMS8 Manufacturer: Linear Technology Description: IC, SM, OP AMP, CURRENT SENSE Download Data Sheet Docket: LTC6101/LTC6101HV High Voltage, High-Side Current Sense Amplifier in SOT-23 FEATURES DESCRIPTIO Supply Range: 5V to ...
  18. Datasheet LTC6101HVACS5 - Linear Technology IC, CURRENT  s AMP, HS, TSOT23-5
    Part Number: LTC6101HVACS5 Manufacturer: Linear Technology Description: IC, CURRENT s AMP, HS, TSOT23-5 Download Data Sheet Docket: FEATURES n LTC6101/LTC6101HV High Voltage, High-Side Current Sense Amplifier in SOT-23 DESCRIPTION The ...
Sort by: relevance / date
