Old 09-05-2012, 02:58 PM   #1
Default Discussion: 18F4550 Proto Board
This board is a Microchip PIC prototyping board for the 18F4550 microcontroller using USB. It is designed to have the PIC loaded with a USB bootloader and then a separate programmer is no longer needed.
More: 18F4550 Proto Board
Old 09-05-2012, 02:58 PM   #2
john_mirolha
john_mirolha is on a distinguished road
hi there!
where are the PCB layout EAGLE files? Only could find a image file!
john_mirolha is offline   Reply With Quote
Old 09-13-2012, 08:48 PM   #3
In the Eagle you can get a picture of the PCB in a graphical format. You will need to select the resolution and file format. If I have free time, I'll try to make a drawing of the PCB in a graphical format. File attached later.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
