Old 12-18-2017, 01:52 PM   #1
Jon
Jon is on a distinguished road
Default Brymen BM869s noise on readings
I just got my new Brymen BM869 and was surprised that something was wrong with it.
He has quite a noise on the readings in all modes and ranges.
This is especially annoying when I try to use min / max. When set to mVolts, there may be a MAX of 200 mV, simply by moving the probes / pins. I use the ones with which he came.
Any ideas or comments on this. Thanks, support is appreciated!
Jon is offline   Reply With Quote
Discussion: Simple circuits reduce regulator noise floor Radiolocman Robot Projects and Advices 1 10-07-2016 03:58 PM
Discussion: White noise source flat from 1 Hz to 100 kHz Radiolocman Robot Microcontrollers (MCU) 1 05-20-2014 06:06 PM
Discussion: Design an ultra-low-noise S-band amplifier Radiolocman Robot Projects and Advices 1 02-04-2014 04:15 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
PCBA OEM and ODM Factory - MOKO Technology
10% Off for PCB and PCB Assembly Order
