Old 08-07-2015, 01:32 PM   #1
Default Simple control a DC motor via Arduino UNO
hi sirs, this is my first topic in this forums ..
i want to control a 12v and a 5v dc motor with 2 terminals only .. not steppers .. and i have not a drive motor shield or its IC. i want not to control their speeds but enable and disable them by my arduino and i fear of high current that can reverse on arduino borad even from a simple 1.5 volt motor so i prefers safety first ..
all i have - my arduino uno & these 2 dc motors and 2 tansistors S15D40 & bld135d
that in my hand at time so can i use them instead of mosfet trans. ? and keep the arduino safe .. knowing that
my pwer source is 12/5 v with 2A
Old 08-10-2015, 05:27 PM   #2
BEMF diode in the event that sudden disconnection of power.
Normally a DC motor that is controlled, generates a DC voltage in the same polarity as the supply, and opposes it.
If turned off suddenly a BEMF in the opposite polarity can occur which is suppressed by the diode.
Servo motor Arduino code tracert Microcontrollers (MCU) 2 07-11-2015 09:56 AM
How I can configure an AVR microcontroller PWM to find the set point using a servo (DC ) motor? tracert Microcontrollers (MCU) 1 06-04-2015 06:37 AM
Discussion: Regulated Automotive Switching DC-DC Converter Radiolocman Robot Projects and Advices 1 11-16-2012 07:58 PM
Discussion: Simple but Powerful DC to AC Converter Radiolocman Robot Projects and Advices 1 06-20-2011 12:02 PM
