Old 06-18-2016, 05:17 PM   #1
crazy-igzp
crazy-igzp is on a distinguished road
Default Square Wave inverter using SG3524N
Hello engineers, I am I newbie, want to make an inverter. I am following the tutorial at http://www.instructables.com/id/250-...ower-Inverter/
I was able to setup the driver stage successfully, but I am having problem with the power stage of the schematic. I used 4 Ń-channel mosfet MT3205 connected parallel, i.e. two on both sides from the driver stage.
The problem I'm having with my circuit is that, the moment I connect the battery terminal to start the inverter, the wire I use to connect the source of all the mosfet to the negative terminal of the battery will burn immediately.
When I noticed this, I increased the thickness of the wire and retest again, and now, immediately I connect the battery to start the inverter, the mosfet will get overheated immediately and get burnt instantly.
crazy-igzp is offline   Reply With Quote
Old 06-27-2016, 07:17 PM   #2
The 3524 schematic has a poor gate driver circuit.
AC Sin wave to RCL circuit rapid Projects and Advices 0 06-09-2016 06:43 PM
Discussion: Voltage inverter employs PWM Radiolocman Robot Projects and Advices 1 01-16-2014 09:29 AM
Discussion: Solar Inverter Battery Charger Radiolocman Robot Projects and Advices 2 02-20-2013 07:28 PM
