Old 07-26-2015, 11:36 AM   #1
Default Controller is not running properly as per logic after removing PICKIT3 programmer
I am using PIC16F877A microcontroller in my application. I have return code for the same and i am programming the chip through PICKIT3 programmer. The board is running as per programming logic as long as PICKIT3 is connected with it, when i remove the programmer the program will terminate automatically after some actions and controller is going in to infinite loop.
Old 07-27-2015, 12:29 PM   #2
1) Turn off Low Voltage Programming (LVP) bit in configuration settings.
2) Connect a 10K resistor from MCLR pin to Vcc.
UART Atmega128 is not working Anatoly Microcontrollers (MCU) 5 01-25-2016 09:13 AM
What environment is better to program STM controller ? maks Microcontrollers (MCU) 1 05-29-2015 11:32 AM
Discussion: Use a transistor as a heater Radiolocman Robot Projects and Advices 1 12-27-2013 08:45 PM
Discussion: mini Logic analyzer on AVR Microcontroller Radiolocman Robot Projects and Advices 1 11-24-2013 07:59 PM
Discussion: When Bigger Is Not Better: Small, Low-Pin-Count Processors That Can Handle the Job. Part 2 Radiolocman Robot Microcontrollers (MCU) 1 11-16-2013 05:24 PM
