Old 11-03-2013, 03:46 PM   #1
Default SD card WAV player on ATtiny85
I gathered scheme on the controller ATtiny85 and SD card. But it doesn't work. Audio files chose WAV format.
After initialization heard the monotonous sound of the dynamics. What could it be?
Scheme and firmware are located below.
Old 11-03-2013, 08:23 PM   #2
For example, Check the Fuse-bits
Old 11-05-2013, 11:18 AM   #3
Thanks Vadzz! That was the problem. Error Fuse-bits CLK
Old 11-05-2013, 11:19 AM   #4
while playing audible noise. What is the problem
Old 11-12-2013, 05:50 PM   #5
Jon
Jon is on a distinguished road
Install the RC filter
Jon is offline   Reply With Quote
Discussion: µProg - tiny, fast, portable AVR programmer with SD. Part 3. Software, Memory card, files, Firmware update, Demonstration Radiolocman Robot Microcontrollers (MCU) 2 03-25-2013 09:40 PM
Discussion: SD/SDHC Card Interfacing with ATmega8 /32 (FAT32 implementation) Radiolocman Robot Microcontrollers (MCU) 2 09-15-2011 09:13 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
PCBA OEM and ODM Factory - MOKO Technology
10% Off for PCB and PCB Assembly Order
Radiolocman facebook Radiolocman twitter
