RadioLocman.com Electronics ru
Advanced Search +
Go Back   RadioLocman Forum > Electronics and ... > Projects and Advices
Projects and Advices Schematics and projects for elrctronic engineers.
Reply
Thread Tools Search this Thread
Old 01-20-2022, 01:47 PM   #1
Radiolocman Robot
Member
Radiolocman Robot is on a distinguished road
Default Discussion: Use a TL431 shunt regulator to limit high ac input voltage
Quote:
Todor Arsenov EDN Most isolated, offline SMPSs (switched-mode power supplies), including flyback, forward, and resonant, must operate at input voltages of 90 to 260 V rms. Some cases even use line-to-line voltages of 400 V rms±10%, leading to increased component-voltage ratings and, thus, increased cost of the overall design.
More: Use a TL431 shunt regulator to limit high ac input voltage
Radiolocman Robot is offline   Reply With Quote
Old 01-20-2022, 01:47 PM   #2
Dr Panda
Junior Member
Dr Panda is on a distinguished road
Default
Hi, new here and new to the tl431. Most of your writing is clear, but two questions.
The 15v zener D2, it also does the tl431 protected for voltages above the max 36V, not only about the Q1?
Is the C2 for eluminate spikes or…? And how do you calculate the value?
Thank you for your articles and time.
Dr Panda is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATmega328 High Voltage Programming DRN_231 Microcontrollers (MCU) 1 05-16-2017 06:12 PM
Discussion: Limit inrush current in high-power applications Radiolocman Robot Projects and Advices 1 02-11-2017 07:38 PM
Discussion: Use a boost regulator beyond its rated voltage Radiolocman Robot Projects and Advices 1 09-28-2014 10:03 AM
Scheme voltage inverter 12v dc to 220v ac mark Projects and Advices 1 11-12-2013 06:00 PM
Discussion: Mini High-Voltage Generator Radiolocman Robot Projects and Advices 2 07-07-2011 12:40 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2023, vBulletin Solutions, Inc.
Only $5 for 10 boards - PCB Service
0$ for 10pcs PCB. Register to get $100 free coupons
Slices ↓
Radiolocman facebook Radiolocman twitter
