Old 12-06-2015, 06:10 PM   #1
Default 16 Bit LCD programming
I'm trying to learn how to program LCD modules with a pic16f73.
Does anyone have some useful information on what I need to know? I understand how to connect each pin up and what there functions are.. but I'm struggle to understand how to write text to it in code. For example how to set the data bus to write "Hello".
I'm using C but assembly is fine if it's easier to explain =)
Old 12-10-2015, 04:28 PM   #2
Please give us more details to work with:
Which LCD module?
Is it a graphic or text LCD?
How is it connected to the PIC?
The manual of the LCD should tell you most of what you need to know. You may even be able to find a library for the PIC that controls just your type of LCD as many LCDs are built around only a handful of different controllers.
Programming an EEPROM tracert Projects and Advices 1 11-28-2015 08:14 AM
Programming Language mark Microcontrollers (MCU) 1 01-04-2015 01:55 PM
Simple ATmega8 fuse bit doctor vgeorgiev Microcontrollers (MCU) 2 11-08-2014 06:38 PM
Discussion: Drive 16 LEDs with one I/O line Radiolocman Robot Microcontrollers (MCU) 4 08-23-2012 11:26 AM
Discussion: RDS Decoder with 2 x 16 LCD for AT90S2313-10 Radiolocman Robot Microcontrollers (MCU) 2 06-28-2012 01:21 AM
