Old 01-31-2011, 07:54 PM   #1
Default Discussion: AVR DDS signal generator V2.0 Part 2. Firmware
Part 1. Schematic AVR DDS 2.0 Firmware As I have mentioned DDS function is a modified Jesper’s DDS algorithm.
More: AVR DDS signal generator V2.0 Part 2. Firmware
Old 01-31-2011, 07:54 PM   #2
This Fuse bits must be programmed: OCDEN, SPIEN, BOOTSZ1, BOOTSZ0, SUT00, SUT01. But on scienceprog.com you will see that JTAG fuse programmed too. I think- it is wrong.
Old 04-01-2011, 11:24 AM   #3
Here's a project for Proteus 7.7 SP2 and AVR Studio project files (in AVR Studio need to use an external makefile).
If someone needs...
Old 04-04-2012, 09:16 PM   #4
KhayamGondal
KhayamGondal is on a distinguished road
sir how can we use 8 bit DAC instead of r2r network
KhayamGondal is offline   Reply With Quote
Old 04-07-2012, 07:00 PM   #5
In this construction, the use of DAC is impossible. You will need to completely change the firmware for this decision. In addition, it would complicate the design, because the DAC will require additional external components.
Old 05-22-2012, 05:59 PM   #6
KhayamGondal
if i use 1k resistors instead of 20k of r2r network than what happens.
