RadioLocman.com Electronics ru
Advanced Search +
Go Back   RadioLocman Forum > Electronics and ... > Microcontrollers (MCU)
Microcontrollers (MCU) Application and programming of MCUs, Evaluation Kits and Demonstration Boards, Programmers.
Reply
Thread Tools Search this Thread
Old 04-05-2013, 09:00 AM   #11
MIRDAS
Junior Member
MIRDAS is on a distinguished road
Default
Good day. HEX file I tested the mega8-16, ATtiny 4313 and revived only mega8-16. ATtiny unresponsive. Still dead. Thank you very much for trying to help.
MIRDAS is offline   Reply With Quote
Old 03-09-2020, 04:00 PM   #12
M0HGU
Junior Member
M0HGU is on a distinguished road
Default
Quote:
Originally Posted by Vadzz View Post
Firmware version 2.07 and PCB with added pulldown resistor for +5V line
"After adding a 100ohm resistor, circuit is more stable, this fixes a problem when some of chips worked in non-HV mode and we can’t fix the RSTDISBL fusebit."
Hi,
I seem to not be able to download the update - I get a 1 pixel gif image only :-(
Any help appreciated
73
Nick
M0HGU
M0HGU is offline   Reply With Quote
Old 03-20-2020, 02:20 PM   #13
Vadzz
Member
Vadzz is on a distinguished road
Default
Hi.
Firmware version 2.06:
"Fixed Atmega324P signature recognition
Added proper timings for Attiny15 on PB.3
Fixed data bug in hvsp „chip erase” command
Added proper additional data for Attiny15 „chip erase” command"
And Fuse-bits begining from version 2.04: H:0xE1 L:0xD1 (internal 1 MHz, EESAVE)
https://drive.google.com/open?id=1lj...4zYuwBDUJSbJf_
Vadzz is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
PCBA OEM and ODM Factory - MOKO Technology
10% Off for PCB and PCB Assembly Order
Slices ↓
Radiolocman facebook Radiolocman twitter
