Old 09-04-2012, 04:14 AM   #1
Default Discussion: Eight-digit counter works with common anode or common cathode
Charaf Laissoub Replace classical counters with a microcontroller. A classical design for directly driving eight seven-segment LED displays requires as many as 15 I/O lines.
More: Eight-digit counter works with common anode or common cathode
Old 09-04-2012, 04:14 AM   #2
AIEDD
AIEDD is on a distinguished road
I am in the process of building this circuit. The code will probably be the hardest portion for me. If possible, could you send the code so that I might copy & paste. I have a melabs programmer using PicBasic Pro. Do you forsee any problems? Thank You for all your support.........Tom
AIEDD is offline   Reply With Quote
Discussion: ATMEL AVR ISP Programmer that Works with AVRStudio4 Radiolocman Robot Microcontrollers (MCU) 2 05-12-2011 06:55 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
PCBA OEM and ODM Factory - MOKO Technology
10% Off for PCB and PCB Assembly Order
Radiolocman facebook Radiolocman twitter
