Old 10-22-2012, 11:43 AM   #1
Default Discussion: Smartec STC-IPM3096A CCD Megapixel Day/Night IP Camera
Sony ExViewHAD Progressive Scan CCD Up to SXGA (1280Ч960) resolution at 12.5 fps Up to 0.003 Lux minimum scene illumination at F1.2, 50 IRE, Slow Shutter Mechanical IR cut filter Frame integration mode MPEG-4/MJPEG compression Backlight compensation Built-in hardware motion detection Alarm input/output Two-way audio transmission Recording to SD card Power supply: 12 VDC / 24 VAC / PoE Service monitor output* The STC-IPM3096A features Sony ExViewHAD Progressive Scan megapixel CCD, providing substantial improvement of several characteristics, including minimum scene illumination, signal to noise ratio and color rendering. SXGA image resolution allows to use the STC-IPM3096A in applications where image detail is critical, while electronic zoom feature serves for visual enlargement of certain image areas.
More: Smartec STC-IPM3096A CCD Megapixel Day/Night IP Camera
Old 10-22-2012, 11:43 AM   #2
cbhattarai
cbhattarai is on a distinguished road
This one seems really adorable. One thing that you can do is that you can add dvr cards to get better access. OR to know more visist : http://www.ad-hocsecurity.com/27-pc-dvr-card
cbhattarai is offline   Reply With Quote
