Old 01-13-2015, 03:28 PM   #1
Default Discussion: Current Source For LED Microscope Illuminator Provides Full-Spectrum Light
James Campbell Electronic Design This relatively simple circuit uses a 6-V DC supply with a PWM current-source configuration to provide efficient, adjustable dimming of a white LED over a wide range, needed to accommodate the unique lighting needs of an optical microscope over its magnification range from 40Ч to 1000Ч When the built-in incandescent light source of my venerable Olympus microscope failed after many years of use, I decided to design a reliable modern replacement. A 1-W white LED (SEOUL X42182, 350 mA max, VF = 3.25 V) was the obvious choice to provide high brightness and full-spectrum light without the heat of incandescent or xenon arc lamps (Figure 1).
More: Current Source For LED Microscope Illuminator Provides Full-Spectrum Light
Old 01-13-2015, 03:28 PM   #2
How not cool, and the control principle is the same. It all comes down to the PWM modulation..
Discussion: TOP242 power source for 10W LEDs Radiolocman Robot Projects and Advices 1 10-14-2014 08:09 AM
Discussion: H-bridge paves new ways for LED lighting Radiolocman Robot Projects and Advices 1 04-01-2014 06:07 PM
Discussion: Ardusumo: an Open Source Platform for Fighting Robots Radiolocman Robot Projects and Advices 2 12-23-2013 07:50 AM
Discussion: ScopeOnPC. Turn your PC into a full featured ocliloscope. Radiolocman Robot Projects and Advices 1 01-26-2012 08:57 AM
Discussion: Motion Sensor for Security Light Radiolocman Robot Projects and Advices 1 09-09-2011 09:42 AM
