Industry-low 160 nA current consumption improves power savings in consumer and industrial equipment ROHM has developed a linear operational amplifier (op amp) LMR1901YG-M featuring the lowest current consumption in the industry. This makes it ideal ...
With a high-performance 160 MHz RISC-V core and a second low-power 20 MHz companion core, this tiny board targets smart home projects. Seeed Studio has launched a new entry in the XIAO family of small form factor microcontroller development boards, ...
New STM32H7R/S microcontrollers raise embedded-application performance to new levels for next-generation smart devices in factories, buildings, infrastructure, eHealth STMicroelectronics has revealed a new high-performance device that punches above ...
EPC introduces the 100 V, 1 mOhm EPC2361 GaN FET in compact 3 mm × 5 mm QFN package, offering higher power density for DC-DC conversion, fast charging, motor drives, and solar MPPTs. EPC launches the 100 V, 1 mOhm EPC2361 . This is the lowest ...
Featuring a VCSEL and smart dual I 2 C slave address, device is ideal for battery-powered consumer applications, including TWS earphones and VR/AR headsets The Optoelectronics group of Vishay Intertechnology introduced a new fully integrated ...
Zero-voltage switching (ZVS) flyback topology and advanced SR FET control enable 95 percent efficiency, reduce power supply size and component count Power Integrations announced the release of the InnoSwitch5-Pro family of high-efficiency, ...
Bel Fuse announced the industry’s only surface mount, PPTC resettable fuse, line-volt-rated to 240 VAC. Designed to protect against electrical overloads and short circuits, Bel 0ZAF resettable fuses provide circuit protection for a variety of ...
HiSilicon, the semiconductor subsidiary of Huawei, has launched the Ascend 910B AI-GPU processor and is enjoying strong orders for the part from across China, according to TrendForce. US restrictions are impacting the sale of AI chips to China such ...
Vishay Intertechnology announced new 6 A, 20 A, and 25 A microBRICK synchronous buck regulator modules designed to deliver increased power density and efficiency for point of load (POL) converters. Offered in a 10.6 mm by 6.5 mm by 3 mm package, ...
New device offers bi-directional power within USB applications Toshiba Electronics Europe has launched their first 30 V N-channel common-drain MOSFET. The new SSM10N961L device offers low-loss operation and is specifically intended for use within ...
