The addition of R2 in Figure 3 solves the falling edge problem, and shutdown occurs immediately after the input voltage drops too low. The regulator's output switches on only after sufficient voltage is present at its input
AuthorsWilliam Lepkowski
Main DocumentArticle «Low-dropout linear regulators double as voltage-supervisor circuits»
DescriptionFigure 5
File Format / SizePDF / 74 Kb
The addition of R2 in Figure 3 solves the falling edge problem, and shutdown occurs immediately after the input voltage drops too low The regulator's output switches on only after sufficient voltage is present at its input
