Circuits & Schematics
Search results: 3,171 Output: 1-10
  1. The key part of any electronic device is the power supply. Any instability or malfunction of the power supply part causes the device to stop working or demonstrate weird behavior. In this article, I introduced an AC/DC flyback switching power ...
    07-05-2024
  2. Story The high temperature of the power components is a known phenomenon in electronics. To overcome this challenge, the designers mount heatsinks on the components to dissipate the heat, however, in many commercial and home appliance devices, the ...
    06-05-2024
  1. Using a blue LED can pose problems when available power-supply voltages don't meet or exceed the LED's 3 V forward-voltage drop. This Design Idea shows how to drive a blue LED from a 3 V battery or another power supply. The circuit in ...
    03-05-2024
  2. I 2 C is a popular bidirectional serial communications bus having a clock and a data line. Both line’s drivers consist of an open drain ground-referenced N-channel MOSFET with a pullup resistor connected to a supply ranging from 1.8 V to 5 V. ...
    03-05-2024
  3. Anemometers are an important category of environmental sensor. Articles about their design, data capture, and linearization have comprised topics featured in EDN Design Ideas, several quite recently. Less well covered, however, has been the topic ...
    01-05-2024
  4. The circuit in Figure 1 is a single-supply version of a programmable Schmitt trigger, or a comparator with hysteresis. A comparator, A1, and a digitally programmable potentiometer (DPP1) are used for the function. The lower (V LL ) and upper (V UL ...
    29-04-2024
  5. AC loads are everywhere around us because at least home appliances are supplied with the mains power. Therefore, we always face the situations that we want to have full control (dimming) over an AC load such as a lamp, a motor, vacuum cleaner etc. ...
    26-04-2024
  6. The challenge of improving analog/digital accuracy by preventing amplifier saturation in systems supplied with only a single logic-level power rail has been receiving a lot of activity and design creativity recently. Voltage inverters generating ...
    26-04-2024
  7. It’s common for I 2 C systems to have both standard and fast devices on the same bus. For I 2 C systems, the speed and power consumption both depend on the values of pullup resistors: the values of them should be low enough to secure the fast ...
    24-04-2024
  8. In the automotive industry, in which the goal is to produce cars with simpler, lighter wiring looms, any interface that uses just one wire instead of two offers a distinct advantage. The circuit in Figure 1 implements a bidirectional link using a ...
    23-04-2024
