Bipolar current source maintains high output impedance at high frequencies
Analog Devices AD8066 AD8065 AD8129 AD8130
Alex Birkett
EDN
Traditional current sources and voltage-to-current converters based on instrumentation and operational amplifiers offer high output impedances at low frequencies because of the amplifiers' good low-frequency CMRR (common-mode-rejection ratios). At higher frequencies, decreasing CMRR, inherent output capacitances, and slew-rate limitations prevent realization of high-quality current sources. Two 200-MHz line-receiver/amplifier ICs from Analog Devices, the AD8129 and AD8130, offer differential inputs and outstanding CMRR, making them strong candidates for building high-frequency constant-current sources. Although the circuit in Figure 1 provides a good starting point, the AD8130's relatively high input bias current can affect output-current accuracy at low current levels.
Figure 1. The 200-MHz AD8130 differential-input line receiver/amplifier
can serve as a basic building block in a high-frequency-capable
current source.
To overcome the problem, you can add a unity-gain buffer, IC2, to isolate the current-sense resistor (Figure 2). In addition, you can use the buffer amplifier to measure the load voltage and bootstrap the output cable's capacitance. The circuit presents an output impedance of about 500 kΩ at 1 MHz and a current-compliance range of 0 to ±3 V using ±5 V power supplies.
Figure 2. Adding an Analog Devices AD8065 buffer amplifier, IC2, isolates
the current-sampling resistor RSENSE and reduces errors that
IC1's input-bias current contributes.
Figure 3. For an ac-coupled current output, add a dc-stabilization loop, IC2A and IC2B.
Current sources that have capacitance-coupled loads benefit from a dc servo loop to stabilize the circuit's operating point (Figure 3). The value of output-coupling capacitor CO depends on the desired low-frequency roll-off characteristic. Further improvements of the basic circuit enable compensation of output capacitance and increase the circuit's output impedance. A small, adjustable feedback capacitor, CCOMP, that's approximately one-half of the output's stray capacitances provides feedforward compensation and further reduces the effects of stray capacitance at the output (Figure 4). To prevent oscillation, the cable's shield-driver circuit's gain should be slightly less than unity. Note that reducing the output-current-sense resistor, R9, to 100 Ω compensates for the input attenuator formed by R1 and R2 and maintains a 1-mA/V characteristic. This voltage-to-current source's frequency range spans 20 Hz to 10 MHz. For best results, use high-frequency circuit-layout and power-supply-bypassing methods.
Figure 4. The complete circuit includes trimmer capacitor CCOMP, which compensates for
stray capacitances in the circuit's packaged layout. Also, note sideband treatment
of power-supply bypass capacitors.
Materials on the topic
  1. Datasheet Analog Devices AD8065/AD8066
  2. Datasheet Analog Devices AD8129/AD8130
EDN
User Name
