Datasheet ADA4500-2 (Analog Devices) - 2
Description10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier
Pages / Page25 / 2 — ADA4500-2* PRODUCT PAGE QUICK LINKS Last Content Update: 04/10/2017. …
RevisionB
ADA4500-2* PRODUCT PAGE QUICK LINKS Last Content Update: 04/10/2017. COMPARABLE PARTS. REFERENCE MATERIALS
ADA4500-2* PRODUCT PAGE QUICK LINKS Last Content Update: 04/10/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Technical Articles
• MS-2066: Low Noise Signal Conditioning for Sensor-Based
EVALUATION KITS
Circuits • EVAL-OPAMP-2 Evaluation Board
Tutorials
• MT-035: Op Amp Inputs, Outputs, Single-Supply, and Rail-
DOCUMENTATION
to-Rail Issues
Application Notes
• MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, SFDR, MTPR • AN-1397: Using the ADM3065E 50 Mbps RS-485 Transceiver in EnDat Motor Control Encoder Applications • MT-095: EMI, RFI, and Shielding Concepts
Data Sheet DESIGN RESOURCES
• ADA4500-2: 10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier Data Sheet • ADA4500-2 Material Declaration • PCN-PDN Information
TOOLS AND SIMULATIONS
• Quality And Reliability • Analog Filter Wizard • Symbols and Footprints • Analog Photodiode Wizard • ADA4500 SPICE Macro Model
DISCUSSIONS
View all ADA4500-2 EngineerZone Discussions.
REFERENCE DESIGNS
• CN0348
SAMPLE AND BUY
• CN0370 Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VSY = 2.7 V ELECTRICAL CHARACTERISTICS VSY = 5.0 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL OUTPUT RAIL-TO-RAIL INPUT (RRI) ZERO CROSS-OVER DISTORTION OVERLOAD RECOVERY POWER-ON CURRENT PROFILE APPLICATIONS INFORMATION RESISTANCE AND CAPACITANCE SENSOR CIRCUIT ADAPTIVE SINGLE-ENDED-TO-DIFFERENTIAL SIGNAL CONVERTER The Challenge The Solution OUTLINE DIMENSIONS ORDERING GUIDE
