Datasheet OP113, OP213, OP413 (Analog Devices) - 8
Description | Low Noise, Low Drift Single-Supply Operational Amplifiers |
Pages / Page | 24 / 8 — OP113/OP213/OP413. 1000. 500. 800. 400. VCM = 0V. S = +5V. 600. 300. RRE. … |
Revision | F |
File Format / Size | PDF / 491 Kb |
OP113/OP213/OP413. 1000. 500. 800. 400. VCM = 0V. S = +5V. 600. 300. RRE. CURRE. S = ±15V. IA 200. CM = +2.5V. INP. 200. VS = ±15V. 100. –75. –50. –25. 125
OP113/OP213/OP413 1000 500 800 400 ) A) A n n ( ( NT VCM = 0V V NT S = +5V 600 300 RRE V CU CURRE S = ±15V V S AS S = +5V 400 V IA 200 BI CM = +2.5V B UT UT INP INP 200 VS = ±15V 100 VCM = 0V
1 14 01 0 6- 6- 28 28
0
00
0
00
–75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 11. OP113 Input Bias Current vs. Temperature Figure 14. OP213 Input Bias Current vs. Temperature
5.0 2.0 15.0 V VS = ±15V S = 5V +SWING 14.5 RL = 2kΩ ) ) V ) 14.0 (V 4.5 1.5 (m (V G +SWING G G 13.5 IN R IN IN W L = 2kΩ W W +SWING S S 13.0 T S T RL = 600Ω U T –SWING U P 4.0 U P T R 1.0 P L = 2kΩ 12.5 T U T +SWING U O R O E L = 600Ω OU E E IV V IV T TI T –13.5 –SWING SI SI 3.5 R 0.5 GA L = 2kΩ PO E PO –SWING N –14.0 –SWING RL = 600Ω RL = 600Ω –14.5
15 0 6- 28
3.0 0
00 2
–15.0 –75 –50 –25 0 25 50 75 100 125
01
6-
TEMPERATURE (°C)
28
TEMPERATURE (°C)
00 Figure 12. Output Swing vs. Temperature and RL @ 5 V Figure 15. Output Swing vs. Temperature and RL @ ±15 V
60 20 VS = ±15V V 40 T S = 5V A = 25°C 18 VO = 3.9V 20 16 B) ) d V 0 R N ( /µ 14 L = 2kΩ V IO ( T –20 IN 12 ARA GA –40 P 10 E S OOP L –60 -L 8 R N L = 600Ω E NNE –80 6 OP CHA –100 4 105
6
–120
13 0
2
01 6- 6- 28 28 00
0
00
10 100 1k 10k 100k 1M 10M –75 –50 –25 0 25 50 75 100 125 FREQUENCY (Hz) TEMPERATURE (°C)
Figure 13. Channel Separation Figure 16. Open-Loop Gain vs. Temperature @ 5 V Rev. F | Page 8 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS PHASE REVERSAL OP113 OFFSET ADJUST APPLICATION CIRCUITS A HIGH PRECISION INDUSTRIAL LOAD-CELL SCALE AMPLIFIER A LOW VOLTAGE, SINGLE SUPPLY STRAIN GAGE AMPLIFIER A HIGH ACCURACY LINEARIZED RTD THERMOMETER AMPLIFIER A HIGH ACCURACY THERMOCOUPLE AMPLIFIER AN ULTRALOW NOISE, SINGLE SUPPLY INSTRUMENTATION AMPLIFIER SUPPLY SPLITTER CIRCUIT LOW NOISE VOLTAGE REFERENCE 5 V ONLY STEREO DAC FOR MULTIMEDIA LOW VOLTAGE HEADPHONE AMPLIFIERS LOW NOISE MICROPHONE AMPLIFIER FOR MULTIMEDIA PRECISION VOLTAGE COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
